The bed slide is as stated on a roller system and will support weight extended or retracted.
The "Level Floor" slides, typically living room or dining area, tilt as they are retracted and are NOT flat on the floor. That leaves a 1 or 2 inch gap and the edge is thin so they look level when extended. That thin edge can break if you walk on it while the slide is in.
There is an awful lot of pressure on the top of the slide against the exterior wall and on the rack and pinion system when that type of slide is retracted. If you walk on the retracted tilted slide floor (even if you miss the edge), you could damage the extension/retraction mechanism or bend the metal top exterior cleat causing a bad weather seal.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
