Originally Posted by Grn_Mtns
Thanks Sounds like a good way to stop the water intrusion. The current metal trim/butyl tape did nothing to keep water off the edge of the plywood. The double sided tape on the side of the ski may be making matters worse by holding in more water than it keeps out.
No problem, glad to help.
It will be a PITA to get the metal trim off, with a combination of half retracted slide to get at that last screw. It might be easier to cut the Eternabond at 1/2 the slide depth and install the first piece from the inside, ( or just the piece that will be buried behind the slide seals when extended) extend the slide and install the second piece.
Definitely buy the metal roller to smash the eternabond real good.
Thoroughly clean the slide box prior to Eternabond installation.
Keep us posted.
