Originally Posted by Chuck_S
Never seen an awning over a sliding room affixed any way other than on the slide itself. Nor do I know any reason for one not so mounted.
Self rolling out/in. No "complexity" -- whatever that might be. Once installed it just works. The weight moving out decreases as the awing unrolls. As noted leaves, rain, and bird poop fall to the ground during retraction.
-- Chuck
Chuck,
Our 2010 Georgetown had the 16’ awning attached to the body of the motorhome above the dining room slide out with its own topper. Between the topper AND the awning, the top of the slide was spotless.
By complexity, I meant it just adds weight and additional wiring to the slide out unit itself. Even when the awning is extended, that amplifies the weight hanging off the slide.
To test this theory......
Hold a pot of water close to your chest
Now hold the empty pot out at arm’s length.
I’ll bet you tired sooner holding the empty pot.
Ken and Terry
