Originally Posted by SeaDog
I'm not sure I understand what you mean by small holes in the corners are your seals not covering the entire slide? Maybe a pic would help
I understand the “small holes” in slide out. I have a 41’ 5th Wheel toy hauler. When you enter the living space, from the garage, you can see daylight in the bottom corner of the slide out where the recliners are located. Not too small. Mine is several inches, like the rubber was too short for seam. I checked to see if the seal was twisted or misaligned, but didn’t see any apparent issues. I thought about sticking a towel in there. Dealers are not competent to fix or provide solution.
I’d be interested in fix solution. Pretty bad when the unit MSRP is $84 K and there are sooo many flaws and issues:-(.
Thanks for sharing.
R/Yukonbill
