Originally Posted by drburns
... I did not like where they ran the wiring, so I ended up using my own...but, it would have been nice to use theirs...
Unless the distance from controller to battery is very short, you'd probably be dissatisfied with it, anyway. Go Power specified to Rockwood that the controller-to-battery conductors should be 8 gauge. For a short distance that may suffice but for many trailers there will be loss due to length.
The prewire also assumes the controller is in a very visible interior location. The only available flush-mount controllers are PWM, limited to 30A. If you want something better, it would be unattractive in the location where the roof wire and battery wire converge.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
