Old 05-31-2018, 02:39 PM   #1
csyrell's Avatar
Stereo Bluetooth
I have a 2018 Ultra-Lite 2902WS. If my phone isn't within a few feet of the radio, the Bluetooth is useless. I cannot sit at a picnic table right outside the door without losing signal, even considering my RV's floor plan has the entertainment center right next to the door!!! Seriously, it's 3 feet from the door and I'm 3 feet outside, and the signal is lost. No point in having BT if you need to be within a cords length of the unit!
Is mine a bad unit, or do others have the same experience? I know these entertainment "systems" are bare-bones-junk, but geesh.
2018 Rockwood Mini Lite 2506S
2018 Rockwood Ultra Lite 2902WS
2013 F150 EcoBoost
csyrell is offline   Reply With Quote
Old 05-31-2018, 02:49 PM   #2
Mine has a fairly good range on it. I haven't measured the exact distance. Make sure to turn the radio off at night. I got woken up one night by music playing outside. Started cussing to myself about who is playing music at 3am. Found out it was us. The phone just started playing music. Thankfully I was at home and the phone was in the house in the bedroom on the far side of the house from where the camper is parked. I think it is a jensen unit.
2017 Wildcat 327RE
2005 Chevy Silverado
2016 Nights camped in wildcat(14) didn't count previous trailer
2017 Nights camped (44)
2018 Nights camped (29) that's too low. Must work on it.
maskins is offline   Reply With Quote
Old 05-31-2018, 02:52 PM   #3
Bluetooth is good for 30ft of clear line of sight with optimal antenna position.
You throw in a few metal door/window frames, other wires, walls, a weird interior placement of the head unit, odd antenna positioning, and you've gone from 30ft down to 10.
I just leave my phone on the counter when playing music via BT.
kfergiez is offline   Reply With Quote
Old 05-31-2018, 02:59 PM   #4
ben31's Avatar
A portable bluetooth speaker probably sounds better than the RV speakers, anyway. Just get one of those and take it outside with you.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 05-31-2018, 03:03 PM   #5
csyrell's Avatar
Understand. I'd just like to be able to enjoy my outdoor speakers without having to leave my phone indoors. Plus, in my picnic table scenario I described above, I'm literally right outside my doorway with not even the screen closed. It's open air between my phone and the stereo. Only issue is that it's a 90 degree angle as the head unit faces to the rear of the camper while I'm outside to the the side of the camper.
What's interesting is that my Samsung watch connects to my phone via BT as well. When my phone is inside my camper, I can walk a good 20 feet away before losing that connection. So it either has to be a super weak receiver on the head unit, or it's defective.
2013 F150 EcoBoost
Old 05-31-2018, 03:05 PM   #6
csyrell's Avatar
I understand, but I shouldn't have to do that should I? My rig has BT and outdoor speakers built in. Plus, I'm not looking to have an outdoor concert hall quality sound. Just would like some background music playing on Zone 3 without having to leave my phone in Zone 1.
2013 F150 EcoBoost
Old 05-31-2018, 03:11 PM   #7
ben31's Avatar
No you shouldn't. I was just giving you an alternative, if the BT didn't connect.
Like kfergiez said, you must leave it pretty close. It also depends on what other BT devices are in use in the area. They all use the same frequencies, so you effective range goes way down in a cluttered RF environment.
Your effective range with BT, between walls, etc. is likely about 15-20 feet. Then you add other BT devices in the area and the range goes down even more.
Ben and Doreen
Old 05-31-2018, 10:27 PM   #8
Nurek's Avatar
Why not use a decommissioned phone as your music player and you can leave it inside and use your reg phone as needed?
I do it at home and in the TT.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 06-01-2018, 05:01 AM   #9
csyrell's Avatar
Still doesn't solve the problem of not being able to control the music from outside. The point of BT is to not be tethered to the unit. Having to keep my music source within 3 feet of the unit means that I may as well be using a cable.
My wife, 15 yo daughter, and I enjoy playing games outside at a table with sirius streaming in the background. That's 3 distinct tastes in music, so the channel can get changed quite often. It's silly to have BT technology but still have to go back inside the camper to change the channel.
Old 07-12-2018, 11:39 PM   #10
You ever figure out a solution. My 2018 21ss has the same issue. Works fine inside but if I am two feet away outside it starts cutting out. None of my other Bluetooth devices have that bad of a range.
Lilharv321 is offline   Reply With Quote
Old 07-13-2018, 05:58 AM   #11
csyrell's Avatar
Unfortunately no.
2013 F150 EcoBoost
Old 07-13-2018, 06:54 AM   #12
Retired JSO's Avatar
No more than we require a griddle, we use a grill mat on our small Webber Q.
Retired JSO is offline   Reply With Quote
Old 07-13-2018, 07:12 AM   #13
Same issue here. One thing I found works well is to have the phone volume at least 75% to make the signal strong for the RV BT to receive. Obviously reduce the Rv stereo volume accordingly. .
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 07-13-2018, 02:16 PM   #14
Grammar Pedant
67L48's Avatar
Same thing here on my 2018 Mini Lite. I have to have my phone within about 2 feet of the trailer. Limits the utility a lot. I like to control my music in real time ... volume control, song selection, etc.
I end up using my Bose Soundlink for my music. I'm not a huge Bose fan for home theater, but this small bluetooth speaker sounds great. Much better lows than the trailer speaker. I know it's not the point. I too would like to be able to use my trailer's speakers. It's just not super convenient to do so.
Good luck.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 07-13-2018, 08:49 PM   #15
I end using my sound link as well. Great little speaker but like you said, defeats the purpose of having outdoor speakers built into the trailer.
Old 07-13-2018, 09:45 PM   #16
So, I know I have really great taste in music. I also suspect some of you guys may be as obnoxious as me ;-). So I actually prefer the smaller speaker that sits close by me so I can hear my tunes AND you don't have to.
I have found lots of times the volume had to be pretty high on my trailer speakers in order for me to hear it down by the campfire. At some point I realize it is too loud and turn it down. I am confident you don't like my music THAT much. ;-)
Bottom line, small BT speaker results in good BT signal AND happy neighbors. I hope you would keep your music down for me as well.
Old 07-13-2018, 09:49 PM   #17
I never have my music blaring. Whether itís through the trailer Bluetooth or sound link. I would however like to be able to sit on the picnic table next to the trailer or even when Iím grilling and be able to use the trailer Bluetooth. Thatís where it cuts off. When Iím by the fire I donít mind the sound link.
Old 07-14-2018, 11:48 AM   #18
Grammar Pedant
67L48's Avatar
Let's not hijack this thread into a campground etiquette thread. The OP was asking for others' experiences with the bluetooth connection to their inside radio ... and if there was a solution to extend this feature.
The only other thought I had was to find a bluetooth repeater. I have no experience with such a device, but here is one example. I'd have to do more research on this before I would personally invest, as the concept of a bluetooth repeater is a bit mixed.
Good luck.
Old 07-16-2018, 08:44 AM   #19
csyrell's Avatar
Good luck.
Thanks. That looks promising!!!
2013 F150 EcoBoost
stereo
