My 2017 26RLWS was not wired for backup lights. Just the stop/turn and running lights. The reverse wire for the 7pin was just capped at the junction box on the tongue. This is the best place to start looking.
I replaced the taillights because I could barely tell the difference between brake and running lights. In hindsight a truck tailight bar would have been a better solution that would have been easier and comes with backup lights with a long wire. Many also provide sequential amber turns which would require a 2 to 3 wire converter if you did it yourself but they have the circut built into them. I had to add a license plate holder and lights after the swap because that was both how the plate attached and how it was bolted on...kind of got into the project before I researched it well...live and learn.
You can check wiring pretty easily by looking where the wires go from the bottom of the trailer in most cases. If you have a sealed underbelly you can still find them in the corners coming through the frame at the corners most times or pull the taillight itself to verify if they are connected at the 7pin. My experience has been they dont run a wire if they have no need to.
For reverse lights I found that just the back was not enough when pulling in at night and you need to be able to see the wheels as well. I put a few cheap led fog lights on from amazon and wired them on the tongue to one of these
https://realtruck.com/p/anzo-univers...xoC7MAQAvD_BwE
I put two in back and two at the end of the aframe by the stabilizers and just turn them on/off with the keyfob. The power I wired to the tongue and put in a waterproof box. I just leave the keyfob in the truck and turn them on manually before backing in. They have come in handy when people get impatient and try to go around me when backing in. Saved an accident at least once.
On the control
1. Is for the lights on the way back
2. Is for the front lights
3. Is for underbelly lights
4. Is for tpms repeater
First pick is reverse lights (all 4)
Second is underbelly LEDs.
Third is taillights and license plate lights.
Good luck!
