Old 04-05-2017, 05:53 PM   #1
Taking Delivery of 3006WK in next few weeks
Any suggestions what to look for when inspecting new camper. I want to make sure I don't get a Friday afternoon camper.
flywthspry is offline   Reply With Quote
Old 04-05-2017, 06:03 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
PDI is your first thing you do and take lots of notes and make sure everything works before you leave the dealer and I mean everything. Make them fix anything that is not right before you leave with the camper. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Traded 2015 30WRLIKS V-Lite
Days camped 2018 67
Days camped 2019 62
Old 04-05-2017, 06:03 PM   #3
crunchman12001's Avatar
Download the PDI check list from the library above.
2015 F-250 FX4
Old 05-09-2017, 11:08 PM   #4
mchayes's Avatar
Download checklist, plan on four hours of walk through, don't let them rush you, open everything, turn everything on that gets turned on, use ever facet, flush it. Go under sinks, check for no crimp,g in,plumbing, and in all wiring. Turn on,shower, check all shower seams, if it moves, make it move, if it turns on, turn it on, take a night light use in every socket, go under with flash light, check EVERYTHING AND LISTEN, go on roof check all seams, check slide seams from,inside while opening and closing and from,outside, check all walls for any warping, check windows, open and close them, check all,hinges. Turn on oven. Microwave..do not give them,final,check till all is done and dont sign final papers. Have them,do first slide lubing thoroughly for you before leaving.
mchayes is offline   Reply With Quote
