Theater Seat "table" issue
Hello All,
I have a 2512S with the theater seating option. On our last trip, the small "swing away" table, that inserts into the arm of the Theater seat, would not insert fully into the receptacle on one side. I tried both tables in the other side and both worked as intended. Also, neither table will insert into the non functioning side, so it's not the table. Upon further investigation it appears that the receptacle in the non functioning side is loose. (see pics) I assume that there is a nut of some sort on the underside to tighten this, and perhaps this is creating the issue. Unfortunately, it appears that there is no way to access the underside.
Has anyone else encountered this issue?
Any suggestions on how to access / tighten the receptacle?
Thanks in advance for your response!
