02-19-2019, 03:06 PM
Thermostat
Is it possible to change the thermostat in a Windjammer 3008 / to a digital thermostat? And what would be involved with doing it?
02-19-2019, 04:54 PM
Which thermostat do you have now?
If it's a Dometic Single Zone then you can't change it without considerable expense. You have to change it and the control box in the A/C and you have to pull new thermostat wiring.
Gotta go campin!
02-19-2019, 06:28 PM
Which thermostat do you have? If it is the Coleman Mach analog with the slide bar to set temps, then yes it can be easily replaced. I replaced mine by ordering the Coleman Mach digital model that looks almost identical. Unscrew the stat from the wall. Remove the old and wire in the new - it is a wire for wire replacement. I moved one wire at a time to make sure I matched them correctly. Attach the new stat to the wall. Note that the screw holes for the two stats are not identical.
New digital stat keeps temps in a narrower range, well worth the cost and effort.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
02-19-2019, 06:33 PM
Not exactly sure but it has a slider on it for temperature instead of a digital readout
02-19-2019, 06:35 PM
That sounds like the one we have where did you get the replacement
02-19-2019, 06:37 PM
How can I tell for sure what one we have
02-19-2019, 07:58 PM
Could you post a picture of it? You could have an answer to what you have and what you need to do most likely in minutes.
02-19-2019, 08:48 PM
Okay I can post a picture of it later this week
02-19-2019, 09:03 PM
I got mine from RVUpgradestore.com which had the lowest price at the time. I'd do a search to see where it's available now.
Coleman Mach 8330-3862 Air Conditioner Thermostat, Single Stage, Heat/Cool Digital, Black $52.28
My original stat looked kind of like this except it was black.
Al
02-20-2019, 12:57 AM
A domestic old style slider analog thermostat can be changed out with a Honeywell digital from Home Depot for less than $30. The only draw back, you will loose the ability to change fan speed.
02-20-2019, 08:38 AM
I have changed the thermostat in our last 2 trailers with the exact one SailorSam indicated. Was quick and easy. I bought ours both times on Amazon.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
02-20-2019, 10:46 AM
Here's a wiring diagram for changing out a Coleman-Mach for a Honeywell (should work for most other brands, too).
But if you go with the Coleman-Mach digital that Sailor Sam shows, it's a wire-for-wire replacement AND it will do the 2 speed fan automatically. If you go with the Honeywell or other brand, you'll need to install a switch for fan speed or just pick one and live with a single fan speed.
I paid about $25 for my Honeywell. The C-M digital runs $45 and up depending on where you buy it.
Good luck.
2011 Traverse LT, 3.6L, FWD
02-20-2019, 12:54 PM
Okay thanks
02-22-2019, 06:39 AM
I checked the stat and it is a Coleman mach
02-22-2019, 05:17 PM
Then it's a very simple swap, in my case the holes even lined up to just screw the new thermostat right back in the same holes.
02-22-2019, 07:29 PM
Easy. Big difference.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
02-28-2019, 07:38 PM
There is more than one Coleman Mach thermostat out there. My previous trailer was a 1 for 1 swap of wires. My 2019 trailer may have a cable with a quick disconnect, with a significantly higher price. I need to pull it off the wall to make sure I get the right one.
02-28-2019, 07:42 PM
Are Windjammer is a 2015 so I hope ours isn't that way because I went ahead and got the Coleman Mach
03-10-2019, 02:29 PM
Installed the new thermostat today the furnace runs can't plug into Shore power right now so don't know if the fan in the air conditioner runs or not hope so. But if the furnace works I must have got it hooked in right
