Old 09-28-2021, 04:53 PM   #1
Tips on toning down LED lights?
Just (finally) got a new mini lite 2511s. Build is good, so far no major issue.
However, the ceiling lights and light above the slideout are very bright. I don't want to replace them, or put in dimmers. I'd like to just place some light dampening film in the light cover of the couch light.
Any other ideas or thoughts? The couch light is just too bright!
If dimmers are the way to go, any easy way to install?
_______________________
2022 Rockwood Mini Lite 2511s
2020 Ford Expedition XLT - Max Towing
jsk125 is offline   Reply With Quote
Old 09-28-2021, 05:11 PM   #2
Trailer Park Supervisor
NJKris's Avatar
Use search to find lots of threads on LED dimmers. I installed a dimmer on mine, it was not difficult and well worth it.
NJKris is offline   Reply With Quote
Old 09-28-2021, 05:11 PM   #3
Just Tryin' to Help
cboss's Avatar
Easy dimmers. This is the way to go. One is for the panel, the other is for remote. Both are easy to install.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ID:	263584   Click image for larger version
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1050
cboss is offline   Reply With Quote
Old 09-28-2021, 05:30 PM   #4
NJKris's Avatar
I used the dimmer in first link you have there. Works well, but lights do flicker when I use a motor, like the awning motor. Not a big deal.
Old 09-29-2021, 01:28 PM   #5
Since we don't normally perform surgeries in our trailer, we also found the overhead leds too bright. I may install a dimmer. In the meantime, a coffee filter, or any kind of paper, trimmed to size and inserted inside the plastic dome, works well.
ElyWhy is offline   Reply With Quote
Old 09-29-2021, 02:15 PM   #6
If your lights have removable covers that will allow for the insertion of a thin plastic film, professional neutral density filter gels, used by photographers, could cut down on the light output without changing the color temperature.
B&H Photo sells them.
Here's a description: https://www.bhphotovideo.com/explora...ensity-filters
Here are the "gels" in a range of choices: https://www.bhphotovideo.com/c/searc...rch=yes&sts=ma
They are cheap enough to experiment with and the various "densities" would allow you to tailor your lighting to different levels.
This would "save" you from wiring in dimmers...not sure it that's an advantage or not, but this is an option. Also bear in mind that some LEDs do not like to be dimmed. They either refuse to dim or they just don't work on a dimmer. Check to see if your bulbs are dimmable.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 09-29-2021, 02:23 PM   #7
I suffer from a similar problem - LED lights are just too dang bright. Even one on is too bright, if I am just sitting there enjoying being in nature. I've tried installing a dimmer switch and it did not help - but that was on the LED strip outside. I like having light when I am preparing foods or actually doing work, but when sitting around, I like it darker. much darker.
After messing with candles, string lights and small electric lanterns, I finally settled on the small lanterns that are dimmable. You can get a three pack at Costco for around $12. This has been my best solution thus far.
WeLikeCamping is offline   Reply With Quote
Old 09-29-2021, 02:48 PM   #8
Just Tryin' to Help
cboss's Avatar
Try this LED strip from Boogey Lights, dimmable, millions of colors, lots of display options, control it with your cell phone.
https://www.boogeylights.com/led-lig...BoCGKkQAvD_BwE
Craig & Cath
Old 09-29-2021, 03:15 PM   #9
stsimmer's Avatar
Try warmer LED bulbs
Most LEDs emit a bluish-white light, which is harsh to the eye, no matter how dim. I replaced all of my bulbs with warm LEDs. Their yellow-white color is closer to that of an incandescent. Much more pleasant.
stsimmer is offline   Reply With Quote
Old 09-29-2021, 04:15 PM   #10
Replaced LED bulbs
I replaced my LED bulbs also. They were cheap on Amazon and simple to replace and much easier on the eyes.
Dan46 is offline   Reply With Quote
Old 09-29-2021, 04:31 PM   #11
BMullins46
Talking
For those of you who think the LEDs are too bright, just wait a few years, mother nature will take care of that issue for you. Personally I wish our were brighter.
Bill Mullins
2016 XLR Thunderbolt 385AMP
2012 Ford F350 DW 6.7 Power Stroke
BMullins46 is offline   Reply With Quote
Old 09-29-2021, 04:53 PM   #12
Just Tryin' to Help
cboss's Avatar
Just curious what Mother Nature has in store?
Craig & Cath
Old 09-29-2021, 05:07 PM   #13
Well, at 80, mother nature hasn't dimmed the lights. But cboss described what does work, and it works perfectly. Installed 1 to the panel, a second to the fixture over dining nook.
grport is offline   Reply With Quote
Old 09-29-2021, 07:07 PM   #14
Keep in mind that you've got the WERV (OneControl) remote control box in your Mini. The dimmer will need to be hooked up post control box, which is not a big deal... however on my 2506S it's behind the stove, so a project for a later date. But as NJ states, its well worth it. You can search OneControl and possibly get lucky finding your OneControl box, they're all over the place (behind oven, behind micro, in an access panel, etc.).
2021 Rockwood Mini-Lite 2506s
2019 Toyota Tundra/2020 LR Discovery
2018 Male Newfoundland
"No such thing as bad weather, just bad clothing..."
Scottnweeze is offline   Reply With Quote
Old 10-04-2021, 08:00 AM   #15
How does one remove the circular led lights in main room of 2511?
Del
Del
2020 Rockwood Minilite 2511S
2012 F 150 Ecoboost
delseb is offline   Reply With Quote
Old 10-04-2021, 09:26 AM   #16
Just Tryin' to Help
cboss's Avatar
Del
Usually you turn the globe CW until it will come off. It takes a little pressure.
Craig & Cath
Old 10-04-2021, 09:46 AM   #17
Georgia Rally Coordinator
aceinspp's Avatar
If they are like mine they are spring loaded so you have to really pull hard to get them out careful as they can bite if fingers in the wrong place. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-55
Old 10-07-2021, 06:37 PM   #18
If it's the round "puck lights", the ones that come with Forest River trailers are awful overly bright junk. We replaced all of ours with these awesome sleek dimmable warm white lights:
https://www.amazon.com/dp/B07BPMSB2C...3dc690b7d7ed26
cube is offline   Reply With Quote
Old 10-07-2021, 07:23 PM   #19
We selected a few and sprayed the inside on the lens with tinting. I still have lots of bright white ones but we sprayed a few with tan window tint works great. We can either have mood lighting or ready for surgery.
2017 3051S Forester
Shadow57 is offline   Reply With Quote
Old 10-07-2021, 07:41 PM   #20
IchLiebeBier's Avatar
I swear, almost every time I visit this site I order something. In this case, it's the RV Lighting Wireless switch.
It says 5A max, and I can't find the the amps per LED puck light. I want to install it at the switch to control all the lights in the series at once. I don't know off the top of my head how many lights are on the switch.
Any idea of the amps? I think they're 3W at 12V, so .25A. Is that about right for the FR lights?
Thanks.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is offline   Reply With Quote
led, light
