01-23-2018, 12:25 PM
tires
i have a 2014 f150 and i need tires.i tow a 2018 rookwood 2606ws.any ideas
01-23-2018, 12:55 PM
Grammar Pedant
You provide almost no details about your TV (wheel size, tires currently on it) or your trailer (size, weight). I suppose I could try to google this stuff and look it up, but I'd rather not. The more info you provide, the better the responses will be.
Truck tires come in two types: P and LT. P are lighter duty passenger tires. They are cheaper, weigh less, and offer a more comfortable ride. LT tires are light truck tires, are more expensive, have stiffer side-walls, are heavier, and offer a stiffer ride.
For towing, you need LT tires. This will put you into D or E load range. The higher the range, more plies the tire will have, the more pressure it can hold, and the heavier the load it can handle ... but it will also be heavier, stiffer ride, and lower gas mileage.
I put LT, E load tires on my 05 F150.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
01-23-2018, 12:59 PM
oh sorry
i have 265 60 18 michelin LTX on it ow was thinking about cooper or toyo the trailer is about 600 empty i weighed it loaded and it was 7100
01-23-2018, 01:09 PM
Grammar Pedant
OK, for that kind of weight, then you definitely should be shopping for LT tires and an E load.
Just search on LT265/60R18 and pick the one that you like best. Your tire is only ~30.5" tall, which will limit your options. Many of the higher rated tires are a bit taller than that.
I went with Falken Wildpeak A/T3 and couldn't be happier. But, your tire size isn't offered at an LT in that brand/make. So, that's a good example of a tire you'd have to ignore.
BF Goodrich A/T is an example of an LT, E-rated tire in your size. Cooper Discoverer is another example. So, they're out there.
If you could stuff LT2 75/6 5R18 in your fenders (~32" tall), then you have more options. But, you'd have to really be sure that those tires could fit.
Good luck.
01-23-2018, 01:11 PM
Wow, you carry a lot of !
I like Michelin
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
01-23-2018, 01:18 PM
Thanks all
I think I will go with the Cooper lt tires
01-23-2018, 01:20 PM
Grammar Pedant
Originally Posted by Crusadernoob
Wow, you carry a lot of ��!
I like Michelin
Agreed. 6,500 lbs of cargo is simply amazing. I'm impressed.
01-23-2018, 02:40 PM
If you get them from Pep Boys, make sure they put the right tires on and check the date code. They installed P rated tires on my truck and when they fixed their mistake and put the right LT ones on, they were 16 months old. Trying to get that taken care of now but so far all I am hearing are crickets...
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
