Old 03-19-2023, 03:11 PM   #1
Toilet Paper Holder
We have a Rockwood 2613 trailer. We are trying to figure out where and whether the self-stick works in a travel trailer. Help please. Thank you. We are new at this.
Ken and Debbie
Ken and Debbie from Texas is offline   Reply With Quote
Old 03-19-2023, 03:28 PM   #2
JWood422's Avatar
Ken and Debbie
I’m not sure self-stick toilet paper would be a good idea anywhere! (Sorry, I couldn’t help it.)
But seriously, self-stick adhesive seems to hold well on hard smooth surfaces.
JWood422 is offline   Reply With Quote
Old 03-19-2023, 04:25 PM   #3
bikendan's Avatar
Moved thread from the Tips and Tricks sub-forum to the Rockwood sub-forum, for suggestions from other 2613 owners.
Old 03-19-2023, 04:44 PM   #4
Canadian Member
We just use a toilet paper holder stand similar to this.
https://www.amazon.com/Minggoo-Frees...%2C107&sr=8-31
Old 03-19-2023, 04:57 PM   #5
Ken and Debbie
Regular self-stick works, but not so much in bathrooms. The high humidity in the bathroom loosens the tape.
We use self stick tape that's made for OUTDOOR applications. Smooth surfaces work best.
Clean the surface with rubbing alcohol, let it dry, then mount the toilet paper holder. It usually takes 24 hours for the maximum holding power. Just make certain you know where you want it to remain because they can be difficult to remove.
The alternative is Command Strips for outdoor applications. That's worked well for us too.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 03-19-2023, 05:03 PM   #6
bikendan's Avatar
We use the same thing.
Old 03-24-2023, 10:33 PM   #7
I found over the cabinet door hooks on Amazon. Modified slightly and drilled holes in the flat hook to mount a TP holder to. Hangs from cabinet door, and stays put. We use the same hooks--was a four pack-- on a different higher cabinet door to hang our bath towels. Over 4000 miles and they haven't fallen off in travel.
Dave and Darren
Max and Riley chihuahua/Jack russell K9 campers
22 Rockwood 8291RK fifth wheel
Our 13th! RV
2019 Denali dually Duramax all stock.
BW companion, timbrens, Fox 2.0 shocks
darndave is offline   Reply With Quote
Old 03-25-2023, 05:49 AM   #8
Ken and Debbie
I mounted a TP holder inside the sink cabinet door using HD adhesive tape and short wood screws.
I wished I’d gone camping sooner in life.
Traveling Circus is offline   Reply With Quote
Old 03-28-2023, 05:05 PM   #9
bruc33ef's Avatar
I use this one. It works fine on my 2023 19FD. The only thing I had to do was crimp the over-the-cabinet part with a pliers about 1/8" so it fits nice and snug.:
https://www.amazon.com/dp/B07TJKG44M...roduct_details
2023 Geo Pro 19FD
2018 Flagstaff T21TBHW
2018 Kia Sorento 6cyl AWD
bruc33ef is offline   Reply With Quote
Old 03-28-2023, 08:03 PM   #10
I bought one of those toilet brushes that stands up in its own container and just slide the roll onto the handle. On travel days, just put it under the sink so it won't fall over. Two birds, one stone.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 03-28-2023, 09:53 PM   #11
Thank you everyone! All great ideas. We finally decided to use command product to stick it on the back of the cabinet door I’m crossing my fingers that it will work. 😊🌻
Old 03-29-2023, 10:34 AM   #12
x2
latner is offline   Reply With Quote
Old 04-03-2023, 06:28 PM   #13
Suburban Redneck's Avatar
We have one like this stuck to the wall with automotive double sided tape. Been there for 6 years without any issues.
Suburban Redneck is offline   Reply With Quote
Old 04-03-2023, 06:49 PM   #14
Retired Old Guy
IamProStreet's Avatar
Same here but just wood screws.
IamProStreet is offline   Reply With Quote
Old 04-03-2023, 07:54 PM   #15
dallasrules's Avatar
I got some little corner metal baskets. They come with adhesive and screw mounts. We put them in the outer corner so that one side is against the outer wall. I used the adhesive on the inside wall and small screws on the outer wall. Works perfectly, and can hold a phone or wipes as well as tp. There were 2 in the set. Fairly inexpensive. I also put up a set in a metal shed I use as an outhouse. Only used the adhesive and they have held for over a year.
BKEJOY Corner Shower Caddy,... https://www.amazon.com/dp/B08MW19MMH?ref=ppx_pop_mob_ap_share
dallasrules is offline   Reply With Quote
Old 04-04-2023, 08:37 AM   #16
pitzhauler is offline   Reply With Quote
Old 04-04-2023, 11:07 AM   #17
bubbles's Avatar
3M automotive tape
Old 04-04-2023, 11:11 AM   #18
We also have ours inside the lower sink cabinet door. I had to remove it and turn it so the slide-on rod is vertical so the TP roll doesn't fall off when traveling.
2021 Rockwood Roo 23IKSS "The Roadrunner"
2019 Ford F150 4X4 Ecco Boost with Max Tow Pkg
Two retirees & Tigger the lover cat
Boondockers since 1982
Jodiwer is offline   Reply With Quote
Old 04-05-2023, 03:49 PM   #19
llibdliw's Avatar
TP holder
2019 FR Rockwood Mini Lite 2109S
2022 RAM 1500 Bighorn, Quad Cab, 5.7 Hemi, 3.92 gears
To get better, you have to get better at what you are doing to get better.
llibdliw is offline   Reply With Quote
Old 04-05-2023, 03:51 PM   #20
Originally Posted by llibdliw View Post
It works, for you.
toilet
