05-09-2017, 03:37 PM
Trailer tires for 8312 TT
What would be the safest AMERICAN tire made for my RV?
I'm looking for load range and brand. I'm looking to replace my "China bombs" before I have issues. I currently have Carlise ST225 / 75 R15. Good tread and wear, just heard BAD THINGS .
05-09-2017, 03:49 PM
Wait for it.... you probably should do a forum search for tires. You may be opening a never ending thread. Tons of info on the forum.
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
05-09-2017, 04:03 PM
Ok thanks... do threads ever end? I'm looking for suggestions and experience. Please comment if you have any two cents. Otherwise thanks
PS
I did a search with limited talk, couldn't find the tons of info.
05-09-2017, 04:14 PM
You probably have not had any problems with your Carlisle's. Great tires. Really great tires.
Sent from my Pixel using Forest River Forums mobile app
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
05-09-2017, 04:18 PM
I have GoodYear Marathon (out of country made) but the new GoodYear Endurance are American made....some members just started to put them on.....
https://www.google.ca/search?q=goody...GcvejwTuhpWoCQ
Fonzie
05-09-2017, 04:36 PM
Thanks for the Info campers!
05-09-2017, 04:51 PM
Scoundrel
After doing much research into trailer ST tires I replaced my original equipment tires with Carlisles Trail HD. You might want to look at reviews and the experience others have had with Carlisle and/or other brands and invest in a TPMS if you haven't already. As someone mentioned above Goodyear Endurance are made in the USA but have only been out since January. I won't invest in any tire that doesn't have several years of a proven track record.
My .02
05-09-2017, 10:23 PM
My $0.03
Every tire shop I have talked with regarding trailer tires has nothing but good things to say about Carlisle. Even if they are MiC. At least they are not some fly by night company that makes 100,000 tires then folds up.
Look at all this discussion on tires. At least 10 pages of results.
https://www.google.ca/search?q=tires...LMPAjwOMgLqgAw
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
05-10-2017, 01:12 PM
Tires & replacement
Lookin2camp,
With 15" rims you have only one choice in my mind. I have had my last ST tire, seen to many failures which typically lead to damage that is expensive to replace. The answer is an LT tire. The only ONE that you can find that covers all the load ratings is an LT Nokian brand, model Rotiiva AT. It is slightly larger (235/75R15), but unless you have close tolerances around your tires, you should be OK. .8 of an inch wider, .6 of an inch taller. With this tire you will have: peace of mind, coverage on weight, speed rating way past what anyone should do with a trailer, longevity - won't replace anytime soon as age does not typically affect passenger tires, safety - no stops along the interstate to change them out. You won't ever hear any comments about regretting having LT tires on their camper! ST tire fans & dealers place blame on the consumer for not operating the tire in the proper ways, but just look as you travel, no everyone who travels fails to air up their tires! Check out the posts on this forum too, lots of opinions. Hope this helps.
05-10-2017, 08:50 PM
Originally Posted by Handydc
2X. I think so as well.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
05-10-2017, 09:00 PM
XLR 24 HFS
05-10-2017, 09:55 PM
Originally Posted by Bpenn
I ran Carlisle RH (before the HD) for tens of thousands without a problem. The HDs are even better. I rarely hit 70 MPH except when passing although they are rated at 75 mph. My truck sweet spot while towing is 63 but generally the cruise is set at 65.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
05-11-2017, 12:19 AM
I think that the Carlisle HD will be my next tires.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
05-11-2017, 05:53 PM
I replaced my MICs when I bought the 5th wheel with Carlisle Trail HDs 4yrs & 15000+ miles ago.
No problems. Lots of tread & 3 years left to replacement.
Ken
TooLoose - WeTrek
04.5 CTD 2500 Dodge 6spd manual
2014 Flagstaff 8528ckws
05-11-2017, 06:02 PM
Time and Time again people brag about Carlisle tires. That must mean something. I don't recall a bad word about them.
David Cournoyer
05-11-2017, 07:42 PM
Ken
I run Carlisle but have not tried that long. I always replace between Seanson 4 and 5.
Generally about 25,000 - 30,000 miles.
05-11-2017, 11:00 PM
Today I changed out my Castle Rocks (65 psi with 1900 miles) with the Goodyear Endurance tires (80 psi). ST225/75R15 E rated vs the D rated Castle Rocks. Took a short 60 mile run and was very impressed. The ride seems smoother and more stable. They seemed to handle the bad roads much better than the old tires. Had metal stems put on also.The stock rims are good for the extra 15psi. Tomorrow I will reinstall my TPMS after I recalibrate for the extra psi and they are cold. Will keep updating as the miles are put on.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
