09-04-2022, 11:54 AM
traveling after 3 months
hello all, happy holiday weekend.
I have a question, the last time we used our geopro 19qb was first week of may. Since then it's been in our driveway as we didn't have as much time to camp as we would have liked this summer. we are now prepping for our fall trips starting next week.
when we last camped, we did not drain the water heater tank, we used city water and did not drain the lines.
question I have is, do I need to flush the lines and sanitize the system (again) before our fall trips? we don't plan on using the fresh water tank this fall. I'm more concerned about the city water side and the water filter under the bed.
thanx for your time and assistance.
cheers,
--nomadicdrave
~nomadicdrave
| 2020 jeep gladiator aka. the gladigator |
| 2020 rockwood geopro 19qb. aka the mobile lair |
09-04-2022, 05:48 PM
If ours sits for more that 2 weeks I will run water through it for around 5 minutes or more hot and cold.
2024 Rockwood 2906BS
2020 Chevy 2500HD Duramax
DeSoto, KS
09-04-2022, 06:15 PM
Scoundrel
If our TT sits for several months I'll typically re-sanitize the entire fresh water system (I do use the fresh water tank). Is it necessary? Probably not.... Just part of my routine of getting it ready.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
09-04-2022, 06:28 PM
drain the tank ... into a bucket check for any contaminates and odors.
if in doubt re-fill it with a bleach water mixture ... or you favorite chemical stuff
run it through your pipes / faucets etc
drain and re-fill
Tarpon Springs FL
2022 Salem 24RLXL
09-04-2022, 07:00 PM
Since you aren't going to use the fresh water tank, drain it and sanitize the city water lines only.
It might not be necessary, but better safe than sorry.
2015 Dynamax REV 24TB class C
09-04-2022, 09:56 PM
thanx all. I'll probably drain the water heater, and just flush our plumbing, not sanitize it, and check the water filter in the camper to see if that has any odor, if so, will probably sanitize the lines.
I've only sanitized the lines by filling the fresh water tank. is there a way to sanitize from the city water side of things?
~nomadicdrave
09-04-2022, 10:26 PM
Yes. Put the correct amount of bleach and water into the fresh water hose and attach to the city water inlet. Then connect the other end to the city water and turn on the water. Then open each faucet til you smell bleach, turn off the faucets and let it sit for a few hours. You don't even have to drain the water heater.
Obviously, you don't need as much as a fresh water tank sanitizing.
09-07-2022, 11:29 PM
I would temporarily remove the filter cartridge prior to introducing bleach thru the city water inlet. Unscrew the housing, remove filter to a clean vessel, and reattach housing. This is also a convenient place to put your bleach/water mixture. You can rinse off your filter prior to re-installing.
Dave and Darren
Max and Riley chihuahua/Jack russell K9 campers
22 Rockwood 8291RK fifth wheel traded
22 Cedar Creek Champagne 38EKS
Our 14th! RV
2019 Denali dually Duramax BW companion, timbrens
09-08-2022, 05:33 AM
My trailer gets used pretty much in the spring and fall and sits for months in between. We don't use the fresh water tank since we're always on city water and the only times I've ever drained the lines is when I winterize it.
Having said this and as mentioned above you can do a few things. When you get hooked back up to water it probably wouldn't be a bad idea to run it for several minutes when you first get set up. The issue with this is that water is going end up taking up room in your grey water storage tanks. For this reason, you might want to do this at home and dump your tanks before you get set up.
A word of caution if you decide to drain the system entirely by opening your low point drain outlets and your hot water heater can run on gas or electric. Make sure the breaker for the hot water heater is off or the switch on the heater is off. If not and the heating element comes on with no water in the tank, you run the risk of burning out the heating element and having to replace it. If you ever make this mistake it's a simple and fairly inexpensive fix.
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
09-08-2022, 06:16 AM
Personally I would just flush the lines and the HW tank.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-08-2022, 08:01 AM
Canadian Member
Like ajlight, I always drain my entire system if it’s going to sit for more than a couple of weeks. So I would definitely re-sanitize the system. It doesn’t take much time or effort. There have been enough stories of bad water, even municipal water supply (Jackson, MS is under a boil water advisory right now), that I don’t take water supply lightly.
