Old 07-14-2018, 07:25 AM   #1
Angry tv hookup
we are moving in full time today to our Windjammer 2012. There is a Toshiba tv mounted to wall. we can't get the tv off to hook up the cable (DISH). help???
nurselady is offline   Reply With Quote
Old 07-14-2018, 07:37 AM   #2
What Kind of cable are you trying to hook up? If it's a dish satellite antennae you probably should use a HDMI cable. Did you install a Dish antenna? We need a lot more details over what equipment was installed . Some pictures and description of your equipment would be helpful too!
Schvarak is offline   Reply With Quote
Old 07-14-2018, 07:46 AM   #3
If the TV was Factory Installed,you Push "Strait Up" to remove! Youroo!!
Old 07-14-2018, 07:47 AM   #4
we bought DISH playmaker. there are three connections available outside. he has the cable run from DISH to outside. he is trying to hook the HDMI cable from
Wally receiver to the tv but can't get the tv off the wall. wondering how to do that? its mounted and doesn't swivel.
Old 07-14-2018, 07:56 AM   #5
Nurselady,what Model # is your Windjammer? Youroo!!
Old 07-14-2018, 08:00 AM   #6
The HDMI cable can be connected to the bottom HDMI port without having to remove the TV from the wall. I couldn't remove mine either so I just found the most reachable HDMI connection port which is working perfectly.
Old 07-14-2018, 10:18 AM   #7
3001W 2012 rockwood windjammer
Toshiba tv
Old 07-14-2018, 10:24 AM   #8
can't reach the plug ins on the back of the tv. how did you do that?
Old 07-14-2018, 11:44 AM   #9
Take pictures of what your TV looks like against the wall.
Old 07-14-2018, 11:50 AM   #10
fonzie's Avatar
try to lift straight up until it release and then pull forward.....that is how my Toshiba is in my 2011 trailer. This video show you when tv is removed.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-14-2018, 12:35 PM   #11
Do you have a camera that you can take pictures of as much as you can see of the bottom of the TV. I have a 2011 MH that was fairly easy to plug in cables.
Old 07-20-2018, 03:45 PM   #12
fonzie's Avatar
nurselady reported back to me and it did lift as in post #10, just to let you all know.
Fonzie
Old 07-20-2018, 04:29 PM   #13
Great!!!
