Old 04-17-2017, 03:10 PM   #1
TV hookup on Rockwood 1905
This is how my TV hookup came from the dealer. (Rockwood 1905 Mini Lite).
1 - Where does the purple wire come from? It goes to my TV cable input.
2 - Why isn't anything plugged into the "Aux/SAT / TV plate? What goes there?
3 - I have two internal speakers and one external. Is zone 1 supposed to be internal and zone 2 external on my IRV unit?
Overall, I could use an explanation of the plumbing. How should things be set up? I've heard that you turn on the booster (on the plate) for antenna, and off for cable - but there's nothing plugged into the plate.
I will either have cable or antenna depending on where I'm staying. We won't have satellite on this unit.
dltrost01 is offline   Reply With Quote
Old 04-17-2017, 03:13 PM   #2
Sorry - somehow my upload got rotated in the process. Not sure how to fix that
Old 04-17-2017, 03:26 PM   #3
Unscrew the plate with the amp on it and see if you have a wire hooked up to antenna my first guess is tha purple wire should be hooked up on the back side of the plate.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
rockwood
