I am not aware of any videos on the subject but you may do a search on You Tube. If you have a label on the wall indicating there is a backer behind it that is where you mount it. In my case I took the very smallest drill I had and drilled a pilot hole to locate the edge of the board, easy to fill with some brown paste shoe polish. One hole should tell you were the backer is located. It does not go floor to ceiling, normally about an 18" square piece of 1/2" plywood (got to keep the weight down). The label for my installs, both bedroom and living area were at the top edge of the backer so I adjusted the position down for the mounting bracket to accommodate. Do not use any screw over 1 1/2" in length or you will go through the wall behind it. I used 1 1/4" heavy screws. I don't recall the size of the screw, I believe they were #12's. You may want to drill pilot holes for screws that size, just don't drill through the wall on the back, put some masking tape on the drill to indicate drill depth. If you are not sure what size pilot drill to use do some tests on some scrap wood. I also remove my TVs when traveling and lay them face down on the bed. For installs that are permanent they use tie straps to prevent movement when traveling. There is a lot of movement in a TT on the road.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
