Old 07-01-2023, 04:13 PM   #1
TV mounting plate removal
Hi, we're removing the tv from a '23 geo pro and are stuck at the last step. We've removed everything (TV, articulating arm) but are stuck at removing the plate on the wall. We've removed all visible screws but it is still firmly attached to the wall. We're suspecting it's glued, but we wanted to make sure it is not attached by fasteners from the back before we start trying to work it loose.
If anyone has any info on how these plates are attached, or if you've removed one, any info you could supply would be greatly appreciated.
Thanks, Kip
2023 GeoPro 20BHS
2021 Ford Ranger XLT
kipkohl is offline   Reply With Quote
Old 07-01-2023, 04:29 PM   #2
OK, never mind.....it's off. For anyone who attempts this project, I was able to carefully pry the base off the wall (after all the screws were removed!) with a stiff paint scraper. Was held on by a black rubbery mastic.
2023 GeoPro 20BHS
mount, tv mount
