Old 03-23-2020, 01:02 PM   #1
Use a Hitch Extender?
I tow a Rockwood Mini Lite 2104S with a 2018 F-150 4x4 and I have no complaints with the truck or TT. My only complaint is that I can't open the tailgate all the way with the trailer hooked up due to the power jack. I looked and repositioning the jack and that is not an option. The only solution I can see is to use a hitch extender. Has anyone else had this problem? Does using an extender affect the towing ? Any info would be appreciated.
hwfahs is offline   Reply With Quote
Old 03-23-2020, 01:17 PM   #2
007matman's Avatar
I would not use an extension.
Do you have a WD hitch on there? They make shanks of varying lengths and drops. I have a big one for my truck. Opening the tailgate is not a problem
007matman is offline   Reply With Quote
Old 03-23-2020, 02:21 PM   #3
007matman's Avatar
Here is a long hitch.. https://www.etrailer.com/Trailer-Hit...RoCq70QAvD_BwE
This is an example of a longer shank as well (if you have a WD hitch).
https://www.etrailer.com/Accessories...RoCSCMQAvD_BwE
I really need to know what you have there in order to help.
Old 03-23-2020, 02:30 PM   #4
Oaklevel's Avatar
Personally I would not recommend using a hitch extender to tow much with.....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-23-2020, 02:37 PM   #5
Use hitch Extender?
Yes I have a WD, rated at 10,000 lbs. and 1000 lb. tong weight.
Old 03-23-2020, 02:40 PM   #6
Jack-E-Up makes an easy removable mount for a jack. Www.jack-e-up.com. Strongly considering one myself.
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is online now   Reply With Quote
Old 03-23-2020, 02:53 PM   #7
Jack
Are you sure you can't just rotate the jack? Works for me. Others have rotated the Jack 90 degrees by drilling another hole in the frame.
Rockwood 2018 Mini lite 2304KS
Avalanche 2500
Nathan 18 is offline   Reply With Quote
Old 03-23-2020, 03:14 PM   #8
Tundra 2014
Jack
This is should a simple issue that FR could fix overnight w/ putting the jacks back 1 1/2" or turn jack 25 degrees when installing. I have a V-front , unable to rotate due to the unequal bolt pattern on jack. I found a 2' extension, solved the problem rated to 10K. This has been this way for a long time. Sore spot as shows FR lack of effort. They could have MFGs change bolt pattern so we had a choice of rotating in new trailers.
Tundra 2014 is offline   Reply With Quote
Old 03-23-2020, 04:29 PM   #9
007matman's Avatar
Then get a longer shank. That's the best way to go. Do you need any more drop? If so, you can take care of that too.. Curt has a nice selection of shanks that have various amounts of length and drop. If you go to their website it's pretty clear. I bought one for my Esky that had a 12" drop (the hitch is in the middle of the bumper) and a 12" extension.
When I bought my F350 I didn't need quite as much drop so I went to a machine shop and had them cut about 3" off the bottom. I don't need the extension but it really doesn't hurt anything there way that it is (watch.. someone will disagree). I've been running this way for two seasons.. hasn't been an issue.
Old 03-23-2020, 05:20 PM   #10
Tundra 2014
Extender
I was going to just buy a 2 1/2" Equal-I-Zer shank for my F-350 truck. When I found that it was going to close to $180 and was not available as an extended version, my set-up didn't look as bad. I am using a Reese 2 1/2" to 2" conversion adapter that extends it back about 2"-about $65. OK for short trips, but I would readjust the WDH if I used this set-up more or was closer to weight limit-8K TT.
It was a pain to line up line up all the adapters and put the WDH in. I was going to weld together but makes a heavy chunk.
PS-Ford no-longer includes the 3' to 21/2' adapter when you buy a new truck-starting w/ 19's ******.Cheap
Old 03-23-2020, 10:06 PM   #11
Swaggler's Avatar
I have the same problem with my new trailer. It came standard equipped with a power jack, which interferes with the tailgate. I plan to replace the power jack on mine with a Lippert manual tongue jack - https://www.etrailer.com/Trailer-Jack/Lippert-Components/LC733926.html -
It costs the same as a hitch extender and wonít effect the weight distribution of your rig.
Swaggler is offline   Reply With Quote
Old 03-23-2020, 10:18 PM   #12
Mr Towed's Avatar
Our jack is so close to clearing that if the front wheels of the truck are down a slight hill it will open and just miss it, otherwise it hits when it's like 75% open, enough for grabbing something but I certainly wouldn't want to step on it. It clears the post, it's just the motor housing so I will likely rotate it like others have said or weld up a new bracket if i'm feeling extra ambitious. There is plenty of room to move it back probably another 6" if I wanted to.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:15Nights
Mr Towed is offline   Reply With Quote
Old 03-23-2020, 11:06 PM   #13
dbledan's Avatar
I was very close with my blueox bit it would not open all the way. I upgraded to a propride P3. Expensive but no sway and I can open the tailgate without any other mods to boot!
I think the rotation should work for you.
dbledan is offline   Reply With Quote
Old 03-24-2020, 08:00 AM   #14
X2
moose074 is offline   Reply With Quote
Old 03-24-2020, 08:28 AM   #15
Rotating the jack worked for me.
Leverage and physics is the reason why hitch extenders are not recommended.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is online now   Reply With Quote
Old 03-24-2020, 08:49 AM   #16
Dave Lyon's Avatar
X2......NO WAY.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 03-24-2020, 08:55 AM   #17
bikendan's Avatar
x3! NEVER use a hitch extender with a WDH.
Equalizer WDH
Old 03-24-2020, 09:23 AM   #18
Chuck_S's Avatar
Equalizer (tm) has a couple of shank lengths available. The longer shank is NOT an extension but an engineered unit. They recommend using the shortest when possible.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 03-24-2020, 09:27 AM   #19
SailorSam20500's Avatar
X2. No concerns dropping the tailgate. Probably >6" of clearance.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 03-24-2020, 10:44 AM   #20
Tundra 2014
Correction
What I am using on my F-350 is Reese Part #38735LB. It is a 3" to 2" adapter and also sets the WDH back about 2.5" so I can open tailgate. The effect to towing my 8K TT is very small. It eliminated all other adapters and the issue of lining them all up. Understanding I have more truck than TT, not possible LOL.
hitch
