Old 10-21-2020, 06:08 PM   #1
Using the winterizing port
I was wondering, Is the winterizing port on the rear of my 2806BS only for hooking up the air compressor to blow out the lines? If so (or not) how does one run antifreeze into the lines? I use to take off the water pump feed and hook it up to a gallon of antifreeze.
Thanks in advance
2023 Rockwood 8294 BS
Curt A16 hitch
2019 F250 crew cab 6.2L 3.73 rear
tmkwasinski is offline   Reply With Quote
Old 10-21-2020, 07:52 PM   #2
Switch the valve on your pump to draw from the winterize port & connect a short hose to the port putting one end in your gallon of antifreeze. Turn pump on and winterize. If you have the factory water filter remove it first as you don't want to draw antifreeze threw it.
dndhurl is offline   Reply With Quote
Old 10-21-2020, 08:45 PM   #3
Winterized my Flagstaff sister to your Rockwood yesterday. Learned something not to do. Do not use a 90 degree elbow in the winterizing port and hook hose to the elbow, hook hose direct to the port. Pump would not draw the antifreeze with the 90 degree elbow.
2020 Flagstaff 26FKBS
2020 Ram Tradesman 2500 6.4 Hemi
Csbadvisor is offline   Reply With Quote
Old 10-22-2020, 08:55 AM   #4
Thanks in advance
No, you blow air through the city water connection and pump antifreeze through the winterizing port.
Iwritecode is online now   Reply With Quote
Old 10-24-2020, 10:54 AM   #5
Exactly! Do NOT blow air into the winterizing port, you are very likely to damage your water pump! Also, just for clarification, do not pump antifreeze into the winterizing port either. The winterizing port is connected to the suction of the trailer's water pump when the valves are aligned correctly. You use the trailer's water pump to suck the antifreeze in.
NavyLCDR is offline   Reply With Quote
Old 10-28-2020, 05:30 PM   #6
Roaminaround's Avatar
One tip for using that connection is to elevate the anti freeze bottle. I have the same trailer. I put the bottle on the bumper and hook up a 2 foot hose to the trailer connection. Make sure your water miser is turned off. I bypassed the inside water filter. If you unscrew the inside filter, you won’t be able to run anti freeze thru the pump.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
Roaminaround is offline   Reply With Quote
winter, winterizing
