Old 10-14-2020, 08:47 PM   #1
MontanaCamper's Avatar
Water filter/purifier bypass
Just stumbled across an item that will bypass the water or antifreeze from filling up the water filter housing. Itís less than $20 and can be left in place permanently if one chooses not to filter the water. It would save one from having to empty the water out of the filter housing each year before winterizing and save from using the rv antifreeze needed to fill the filter housing. It would save one from making a wet mess when removing the filter housing too. FLOW-PUR FP-WP100Click image for larger version
2017 F150 4x4 3.5 Ecoboost 3.55 Gearing
2021 Rockwood 2104S
MontanaCamper is offline   Reply With Quote
Old 10-15-2020, 09:24 AM   #2
SeaDog's Avatar
$20 is about 8 gallons of antifreeze. I guess I don't see the advantage of this product other then saving the small amount of antifreeze in the filter housing, you still have to remove the filter (wet mess) before winterizing. The antifreeze in the filter housing is flushed out when you restart the system before inserting the new/clean filter. Am I missing something here?
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-15-2020, 09:26 AM   #3
Greywater's Avatar
I keep a bucket under my filter housing when I remove it. No wet mess yet, but I always have a towel handy.
I havenít been everywhere, but itís on my list.
2021 Geo Pro G16BH
2012 Nissan Armada 4x4 Platinum
Greywater is offline   Reply With Quote
Old 10-15-2020, 02:04 PM   #4
Did not intend to endorse this product in making the above post but just wanted to put it out there as an idea for those that might be interested. For me, I was looking for a way to bypass the water filter and this looks to be a way to do that without doing any plumbing work. As the filter is located in a hard place to access I just don't want to be bothered with messing with the filter, ever. As my new 2104S camper has not arrived yet I have obviously not had to chance to install the bypass but will have a chance to see how it works out next spring when getting the camper ready to travel. If I decide to filter the water I may just use one of the inline filters that attach to the hose while filling the fresh water tank or to the city water connection. I understand that we are each entitled to our own opinions, this is mine.
Old 10-15-2020, 02:26 PM   #5
I respect your opinion, understand your thoughts and the difficulty to get to the filter... but... you're going to need to get there to put the bypass plate in place. Do you know several folks have complained in other threads the bypass plate leaked and/or didn't fit properly? It seems these bypass plates are filter specific to fit properly. Is your filter a Flow-Pure?
Since you mentioned never wanting to mess with the filter again, you may want to consider removing the filter totally and bypass it with a $2 coupler.
Days Camped: '18=51 '19=58 '20=110 '21=21
Old 10-15-2020, 02:44 PM   #6
Greywater's Avatar
I'm firmly in the "more filters the better" camp. I use a portable "on the hose" filter and kept the one mounted in the trailer. Mine's not too difficult to get to, but it was not mounted very well at all. I ended up re-enforcing the mount by adding some wood and screws to stiffen it up. I'll be adding a catch basin and drain at a later date in case it starts to leak.
I have seen filters that have a built in bypass line, which may be an option for those not wanting to fill the filter chamber with antifreeze. You still have to remove the filter eventually, so it's probably a good idea to make it a hassle free job if possible.
2021 Geo Pro G16BH
Old 10-15-2020, 11:55 PM   #7
jbcrick's Avatar
Well, it won't fit the filter housing on my Geo Pro 19QB. Might want to check your filter housing model. This is what I found while searching for this bypass plate.....
Nikki, My Black Lab and Travel Buddy
2020 Rockwood Geo Pro G19QB
2016 Nissan Frontier SV 4WD
AF&AM, Lodge #584 of North Carolina
jbcrick is offline   Reply With Quote
Old 10-19-2020, 09:16 PM   #8
Roaminaround's Avatar
I just clipped the lines and bypassed the filter. I also hate filling that canister up with antifreeze. It makes no sense. I run a 2 stage filter externally in a tote with my hoses. Much better system than the single stage inside.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
Roaminaround is offline   Reply With Quote
Old 10-19-2020, 09:26 PM   #9
SeaDog's Avatar
You might consider doing what I did. Remove the filter and bypass it take the mounting bracket bend it flat drill a hole in it and your back bumper and mount the filter on the bumper to filter all incoming water.
Retired Navy
Old 12-07-2020, 08:34 AM   #10
This kit will NOT fit the water filter canister on the Rockwood campers. Unfortunately I sent for the kit only to find that it does NOT fit. As my new camper had been winterized at the dealership I found out firsthand how difficult and messy removing the filter canister is. Spilling the pink RV antifreeze all over the place even when using a pan underneath seems unavoidable. It's not going to happen again as I cut the lines to and from the filter assembly and spliced them with a 1/2" barbed connector. I removed the filter assembly completely.
bypass, water, water filter
