Originally Posted by Jim S JR
Check your shower miser valve to be sure it's off. If you have one.
? The Miser valve either diverts water back to the fresh tank, or to the shower head, but only when the shower water valves are on in either case.
Since the Miser valve is after the shower water valves, how would it's position cause intermittent hot/cold fluctuations?
If the Miser valve is open, no water comes out of the shower head (it is going to the fresh tank), and if it is closed, the water comes out of the shower head like normal.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
