Old 05-15-2021, 05:49 PM   #1
Water leak
Does anyone know what size the clear braided line and the oitiker clamp size is on the water line coming in from the city water inlet. I have a small drip and need to remove the clamp, it says 17.5 on the clamp but not sure what size that is, and cut the line and put a new clamp on and crimp it on the line. Want to know the size of water line and size of clamp to buy before I start cutting.thks in advance.Click image for larger version
sims is offline   Reply With Quote
Old 05-15-2021, 06:46 PM   #2
take a pair of side cuttersc," dikes" not sharp ones and squeeze band at crimp base , just a little.
Thomas ho is offline   Reply With Quote
Old 05-16-2021, 12:12 AM   #3
Or use a crippling tool. I’ve had good luck just tightening the bands when I’ve had small drips. If yhe factory tool is out of spec, which could happen easily, you’ll have leaks. Good luck, but try it before you cut and replace anything.
2021 Rockwood MiniLite 2507s
2015 F 150 SC 2.7 EB 3.73 Equal-i-zer WD hitch
Roadmaster Active Suspension
Reno8220 is offline   Reply With Quote
Old 05-16-2021, 08:08 AM   #4
Thks
Old 05-16-2021, 08:09 AM   #5
Thks
Originally Posted by Reno8220 View Post
Or use a crippling tool. Ive had good luck just tightening the bands when Ive had small drips. If yhe factory tool is out of spec, which could happen easily, youll have leaks. Good luck, but try it before you cut and replace anything.
Old 05-16-2021, 08:29 AM   #6
nomad297's Avatar
That is 1/2” braided PVC water line. The inside diameter is 1/2” and the outside diameter is 5/8”. It is designed to be used with standard 1/2” PEX crimp or clamp rings.
Bruce
Old 05-16-2021, 08:43 AM   #7
Thanks for the sizes I will check for parts
Originally Posted by nomad297 View Post
That is 1/2 braided PVC water line. The inside diameter is 1/2 and the outside diameter is 5/8. It is designed to be used with standard 1/2 PEX crimp or clamp rings.
Bruce
Old 05-16-2021, 06:26 PM   #8
mpouls1's Avatar
I got this kit off Amazon because I had the hardest time figuring out the correct size to use. I think when I spliced a shut off valve to my toilet I used the 15.3-18.5mm. The OD is too big for the 1/2 inch pex clamp, I could not get it over the tubing..
When I swapped out my water heater bypass I changed out the tubing and hardware because the ID like stated above is 1/2 inch, but the fittings are much smaller so its no wonder they leak, which it was doing on multiple connections.
ID:	254703Click image for larger version
2019 Flagstaff Microlite 25LB
2021 Silverado 3500 HD CCLB
2018 Escalade ESV
2009 CTS-V
mpouls1 is offline   Reply With Quote
Old 05-16-2021, 08:07 PM   #9
llamb's Avatar
The clamps are for PEX tubing. The braided PVC should use common hose clamps.
Stainless Steel Hose Clamp
Larry
2021 Riverstone Legacy 42FSKG
2016 RAM 3500 DRW
llamb is offline   Reply With Quote
Old 05-16-2021, 08:15 PM   #10
I agree.... there in lies the problem. The manufacturer uses clamps. I’ve had luck replacing the clamps on the white hose with worm gear clamps available at auto parts stores. The ones for gas line works best.
Old 05-17-2021, 08:19 AM   #11
jeff64's Avatar
No! You want 360 deg. clamping force which you don't get with screw clamps
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
jeff64 is online now   Reply With Quote
Old 05-17-2021, 08:54 AM   #12
If you purchase clamps for fuel injection hose they are a screw clamp that provides 360 deg clamping.
The worm drive clamps tend to cut into hose and often need to be retightened which makes them cut deeper.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-17-2021, 10:34 AM   #13
Right Titan Mike. That’s the ones I’ve used. I misspoke calling them worm gears. Thanks
Old 05-28-2021, 12:54 AM   #14
RedRoverComeOver's Avatar
Originally Posted by sims View Post
Does anyone know what size the clear braided line and the oitiker clamp size is on the water line coming in from the city water inlet. I have a small drip and need to remove the clamp, it says 17.5 on the clamp but not sure what size that is, and cut the line and put a new clamp on and crimp it on the line. Want to know the size of water line and size of clamp to buy before I start cutting.thks in advance.Attachment 254642
Have same leak on a 2021 G16BH. Didn't realize until I had to park overnight with trucks on a highway shoulder and the pooled water made its way into the bathroom floor.
RedRoverComeOver is offline   Reply With Quote
leak, water, water leak
