This generic plumbing pic may help you. Covers probably 95% of RV's. As 5picker said, if you have the 3-way valve, you will leak to either the AF connection or the FW tank. If you have the 2 separate valves, you'll be better off as you can close both of them if you can't get the check valve to re-seat.
2011 Traverse LT, 3.6L, FWD
