An average water pump will use 5 amp hours if you run it for an hour.
Most pumps put out around 2.5 gallons per minute. Chances are the only time you use that much water is for a shower.
With this in mind I'm guessing a water pump runs for maybe 1-2 minutes per day in total if not showering thus power consumption by pump will be less than one amp hour per day.
A furnace is usually the biggest user of battery power but only when cold.
