Old 10-06-2022, 02:41 PM   #1
grege's Avatar
water pump connections 2608BS
Hey all,
Looking to add a Topargee water tank gauge to my water tank feed. Showermiser says the best location when you have and use the showermiser is to put the sender unit is between tank and return line from the showermiser.
Attached are pictures from my 2608BS where I marked 3 lines at my water pump. Line 3 is the antifreeze input that goes to the valve. So do you think line 1 or 2 is coming from my water tank? If I follow 2 it connects to a blue pex hose (picture showing it attached) so I am thinking that is showermiser return coming from my shower. I'm thinking best guess is line 1 is going to my water tank. Anybody know?
Greg
ID:	280140   Click image for larger version
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
grege is offline   Reply With Quote
Old 10-08-2022, 09:45 PM   #2
grege's Avatar
I used a clamp to clamp the hose and figure it out. Got the water flow meter installed today.Click image for larger version
ID:	280219Click image for larger version
ID:	280220Click image for larger version
'22 Rockwood 2608BS
2608bs, pump, water, water pump
