Originally Posted by erm626
Last Question on the water miser valve for me. When it come to winterizing. You are pumping antifreeze to the shower. Do you first pump the antifreeze to the shower head by opening the hot/cold controls. Do you need to do anything to the water miser control valve lever ? If the lever is open aren't you just sending antifreeze to the fresh water tank ?
That question has been posed before.
The answer seems to be:
- Run water through the showerhead until it runs pink
- Switch the WaterMiser for a very brief period (a couple of seconds)
This puts a tiny bit of potable antifreeze into the fresh water tank. It's not a perfect solution, but if you use the fresh water tank you are likely to give it the 12-hour Clorox soak in the spring which should pretty well flush it.
Typical soak is 1/4 cup Clorox for every 16 gallons. You would put in the Clorox, fill the fresh water tank, and use the pump to flush a bit of the solution through all the plumbing. Wait 12 hours, drain the tank and flush with fresh water.
