Most wifirangers in the FR line from 2020 are a Sky 4 unit. These can be upgraded to take in cellular signals rather than just wifi from campgrounds, etc. You need to buy Wifiranger's "LTE upgrade" kit plus a data plan that is supported. Then you continue to connect the wifiranger's wifi signal you have been. It's source is just changed from other wifi to celluar
it is NOT a booster, just enables cellular connection but being outside the aluminum skinned trailer and at a higher elevation, it may get more signal than your phone.
But (there is always one of these right?), the wifiranger uses a "2x2MIMO" antenna where as most smart phones and many hotposts use "4x4MIMO" so the phone/hotspot already has more "signal gathering ability" so the roof mount benefits of the LTE upgraded wifirange is not always worth it.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
