Old 10-02-2015, 10:45 AM   #1
Unhappy Windjammer awning "bang"!!
Every time I extend the main awning on our 2016 Windjammer 3029W I get this big bang from the awning that shakes the trailer. Sounds like it's hanging up on the front strut and then letting go. Retracting is fine.
Had it back to the dealer and they say it's a know problem with Windjammer awnings because of some delay in the mechanism.
Sound fishy to me as the second awning over the dining room slide never makes this noise and it works fine. Both awnings have the metal shield that covers it when retracted.
Anyone else had this problem??
Many thanks,
billb800si is offline   Reply With Quote
Old 10-02-2015, 10:49 AM   #2
Go to another service center,tree are NO special awning on our V nose units! Youroo!!
Old 10-02-2015, 10:53 AM   #3
jeff64's Avatar
I've seen this too. I don't think there is anything to get too excited about here. Have your wife push the extend button while you go out an watch it. Seem as though it kinda gets overcenter and the gas shock takes over and takes up any slack in a hurry
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-02-2015, 11:00 AM   #4
D_B Travelers's Avatar
Mine does this also. I believe Jeff64 is correct in that the geometry is over-center and it has to get past that. I haven't seen any rub marks on my awning arms or on the brackets so I have just lived with it. My awning does roll in slightly crooked, but the DW pushes the switch while I apply gentle pressure and it winds up just fine. I am sure a wind gust twisted it slightly, but I am not going to try to twist it the other way and risk breaking something.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 10-02-2015, 11:51 AM   #5
ov845's Avatar
Ours sometimes does it. I've never noticed anything bent or binding when rolling it in or out.
Happy Camping!
2012 Ram 1500 5.7L 3.92
Airlift 1000
2015 2809W WindJammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 10-03-2015, 08:45 AM   #6
strat56's Avatar
Mine does it too. I saw a video on youtbue that stated it was because of the motor being on one end of the awning and causing the awning to torque a little when it;s being opened.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 10-03-2015, 09:39 AM   #7
It doesn't take much to put a slight bind on an awning. Extend the awning and make sure the material is exactly centered on the roller and then pop rivet (thru the side hems) both ends of the material to the tube. Note: run the awning in and out a couple of times to insure it is centered BEFORE pop riveting the material.
Old 10-03-2015, 10:03 AM   #8
Georgia Rally Coordinator
aceinspp's Avatar
I have the same issue with mine. I just run it out slightly then give it a nudge with my had and then it rolls out. No biggie. Material looks to be centered. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Traded 2015 30WRLIKS V-Lite
Days camped 2018 67
Days camped 2019 62
Old 10-05-2015, 12:09 AM   #9
TimVWulp's Avatar
Many thanks,
Hi was having the same problem with my awing arms not opening and then snapping open. I have a 2015 flagstaff V lite wikss diamond. The 3025 is rockwoods twin sister to the wikss. Dealer had a dometic rep look at awning and had them install two rubber bumpers in the arm tracks that help give the arms a kick open. The bumper arm kit is MFG # 331077.00. So fare no problems with the arms not opening and coursing the awning to snap open.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 10-05-2015, 05:44 AM   #10
Alleged curmudgeon
Vern's Avatar
After installing self-storing awning tie-down poles, my awning developed this same symptom, although I have never seen it as a particularly big deal, as it never truly "binds" or appears stressed. I usually just stop after extending the awning about half-way out, which encourages it to "catch up". The front strut then pushes it up to level with the rear and it extends normally from there. I wonder if this is the flip-side of adding a little weight to an awning with the self-dumping feature, which requires that the mechanism be a little loosey-goosey to begin with.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30)]
Vern is offline   Reply With Quote
Old 10-05-2015, 06:29 AM   #11
TURBS's Avatar
Mine has done it since new.
It 5 years old now.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 10-05-2015, 06:55 AM   #12
aceinspp's Avatar
Hope this helps Tim
Thanks for the info. Any pics of the install just in case I want to order. Later RJD
Days camped 2018 67
Days camped 2019 62
Old 10-05-2015, 07:31 AM   #13
jeff64's Avatar
I'm wondering too if the tension on the knobs that would hold the awning in the lowered side position (for rain runoff) doesn't have a great bearing on this condition. I could see where having both really loose would let the awning freely slide, but, just snug enough to slip/slide would hold it in place while deploying until sufficient force was exerted by the gas shocks to overcome that tension in one big hurry. BANG!
14K Equalizer
Old 10-05-2015, 07:44 AM   #14
Gleaner's Avatar
Hope this helps Tim
Good info, thank you.
Mine are a little loud when first being deployed, but don't shake the whole TT.
2015 nights camped (54)
Gleaner is offline   Reply With Quote
Old 10-05-2015, 08:59 AM   #15
dieselbobcat's Avatar
Same on out 8312SS with two awnings... they both have the same opening bang.
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 10-05-2015, 12:58 PM   #16
nomad297's Avatar
No bang on either of the awnings on my 2016 Windjammer 3029W.
Bruce
Old 10-06-2015, 08:36 AM   #17
I get it in our 2304s regularly. Bugs the wife but after watching what is happening, it really doesn't look like much to worry about.
chriszke is offline   Reply With Quote
awning, windjammer
