Originally Posted by sbell123
Thanks for the replies. I will be crawling underneath this weekend to look for the low point drains.
The location of your low point drains should be indicated by decals on the side of the trailer. They are close to the outside, near the waste drain, above the curve of the lower trim. I put valves on the ends of mine so I can just reach underneath to open them.
The filter Capt. Mike referenced is in the forward, left compartment, where the water heater and water pump are located.
You can PM me if you need to know anything about your 2604. Mine's a 2014.
