If it's an "antifreeze inlet," does that go to the pump bypass? Because otherwise you can just pump antifreeze into the city water inlet. Not sure why another inlet is helpful. Most often the bypass valve has a separate white line connected to it that goes directly into the antifreeze jug.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
