Old 03-25-2017, 08:57 AM   #1
Winterizing help
Just got my rockwood and the guy left a bunch of water in it. Drained everything I could and read several posts but I have no idea which of the 7 valves are the "bypass valve" (or its purpose ) and ill be damned if I can't figure out how to remove the filter housing. ( tried twisting both ways...and harder I'm sure it will break!)
schwim15 is offline   Reply With Quote
Old 03-25-2017, 09:05 AM   #2
With no Info on Model of your Rockwood I can only Help with your Filter! Turn on a Faucet,leave it on,Now take your filter wrench and slip it on the body,hold the bottom of the body with your other hand,and PULL on the wrench handle! Youroo!!
Old 03-25-2017, 09:06 AM   #3
No wrench. Which way? Twist to right or left?
Old 03-25-2017, 09:07 AM   #4
2608ws if it helps
Old 03-25-2017, 09:11 AM   #5
Make sure to relieve the pressure first. Generally righty tighty lefty loosey (except on the old style propane tanks!)
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 03-25-2017, 09:11 AM   #6
fonzie's Avatar
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
winter
