Originally Posted by kipkohl
Not sure if this post should be here or under electrical, but it's a Geo Pro trailer.
I'm wondering if anyone knows what gauge wire Rockwood uses between the solar controller and batteries on the new trailers with the 190w panel and Go Power 30a PWM controller?
I want to upgrade by adding a 2nd 190w panel, 30a MPPT charger, and two 100w LiFePO4 batteries. If I keep the controller in the same spot, the length of the run would require 4g wire. I'm kind of assuming Rockwood didn't run 4g, but if someone knows for sure that would be great.
Thanks for any info you might have.
To answer your first question re: wire size I would answer "Too Small".
Usually there is a lot of #8awg wire used from chargers/controllers to batteries which is OK if the controller is close to the batteries.
For a 30 amp Solar controller like yours, which will deliver no more than 30 amps, however the distance between controller and batteries becomes a big factor.
Using this calculator
https://www.wirebarn.com/Wire-Calculator-_ep_41.html you can see that 30 amps on a #8 wire will yield a 2% voltage drop (or less) as long as the TOTAL length of wire (both directions) is no greater than 14 feet. That would translate to 7 feet one way.
Of course if you can tolerate 5% voltage drop (which means wasting a scarce resource) then #8 awg wire is OK for up to 36 feet or 18 feet one-way. Unfortunately a 5% voltage drop on a 12v system means that 13.8 volts (avg charging voltage) will now drop to 13.1 volts which is barely a trickle charge.
One solution is of course to move the Solar Controller to a point as close as practical to the batteries. The higher voltage coming from the PV panels overcomes the resistance of the wires supplying power to the controller and the shorter wires carrying the output to the batteries will have less total resistance resulting in less voltage drop.
One thing often overlooked when just using "tables" is the fact that 12 v wiring is for Direct Current and unlike 120vac wiring wire length is BOTH DIRECTIONS. If your controller is 15' from the batteries then for wire size calculations it's really 30' for calculation purposes. Your statement that #4 wire would be required was correct for most trailers based on where FR mounts controllers (and converters) in relation to the batteries. With #4 awg wire however there is a problem. Most Controllers won't accept wire sizes greater than #6awg.
In summary, if you want to maximize the charging capabilities of your solar panels/controller, moving the controller closer to the batteries is highly recommended. Roof mounted panels already give up output due to the inefficiency of flat mounting and even more is given up with voltage drop issues.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
