Old 04-16-2018, 06:09 PM   #1
Hank/NJ
X-chock for rockwood 2304ks
I'm looking for some extra stability for our 2018 rockwood 2304ks. I'm assuming the X Chock is the way to go? My tires are only 2 1/2 inches apart
from each other.. Does anyone have suggestions of what would both fit and work ?
Hank
Hank Kunz
Rockwood 2304ks
2013 Ford F150
hankyk is offline   Reply With Quote
Old 04-16-2018, 06:42 PM   #2
The following from amazon.com work great for my 2018 2507S Mini Lite :
X-Chock Wheel Stabilizer - Pair - One Handle - 28012 from Amazon
Provides added stabilization and prevents tire shifts by applying opposing force to tandem tire applications
As opposed to other chocks, the X-Chock works with the tires’ natural movement instead of against them
Fits even the tightest of applications retracting down to 1 3/8” and extends to 10”.
Rust inhibitive coating.
Plated ratchet wrench with comfort bumper included
Item weighs 11.2 lbs
I don't know if this link will work but here's the link:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2017 Ford 2.7 Ecoboost
2018 Rockwood Mini Lite 2507S
isobar is offline   Reply With Quote
Old 04-16-2018, 06:50 PM   #3
Hank
That's what I'm using on my Mini Lite 2503S. 2-1/2" tire spacing. Works fine.
2011 Traverse LT, 3.6L, FWD
Old 04-16-2018, 07:42 PM   #4
Grammar Pedant
67L48's Avatar
That's exactly what I bought for my 2018 2504S. Fits great.
Good luck.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 04-17-2018, 01:51 AM   #5
kdp1897's Avatar
Not sure on the exact measurement on our 2618VS, but it is much closer than our old Wildwood I originally bought the x-chocks for. They did fit but it was close.
2017 Rockwood Ultra V 2618VS
2017 GMC Sierra 1500 SLT Crew Cab Z71, 5.3 EcoTec V8
Nights Camped: 30 in 2019; 39 in 2018
kdp1897 is offline   Reply With Quote
Old 04-17-2018, 12:30 PM   #6
I recently added a pair to my 2109S MiniLite and they really lock the wheels in place.
I paired them with the LevelMate Pro and I'm happy with both.
Try this link for the later.
hthavana is offline   Reply With Quote
Old 04-17-2018, 03:54 PM   #7
McRabbet's Avatar
I use a pair on my Rockwood UL 2304DS without an problems. The fit is close, but they do get in between the tires and keep the trailer in place when tightened.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
McRabbet is offline   Reply With Quote
Old 04-17-2018, 04:20 PM   #8
.... Does anyone have suggestions of what would both fit and work ? ....
the BAL X-Chock 28012(a 2 pack) is the correct one for you, and they work great, .... the larger model is 28014(a single) and is for wider spaced axles, ...
fella10 is offline   Reply With Quote
Old 04-29-2018, 02:18 PM   #9
Hank/NJ
We picked up a set of the 28012s and we used them this weekend.
They fit and work perfectly !! Thanks for all the comments.
Hank Kunz
Rockwood 2304ks
2013 Ford F150
2304, rockwood
