Originally Posted by dlorsi7
We have a Surveyor 2017BHDS that had water coming out from fresh water tank while hooked up to city water. Water was leaking coming into lower wall in bedroom. Thinking maybe blocked or faulty in-line check valve. Any solution or recommendation to problem?
Had the same experience. Check valve had debris in it. Turn off outside water source and cycle your fresh tank for a while. Usually works.
