I put these on my 2018 Forest River Surveyor. The quality is good. Easy to install as long as you take note of what the install and configuration of the key lock you are removing is. Also a tip, change the Combi-Cam lock code before you permanently install and try to close the lock on the storage compartment door. If you mess up this process with the door closed/latched you may not be able to get it open again. FYI. Nice to have easy access and comfort of keeping a spare set of keys in there when needed. I got them on-line at Amazon Canada and they were shipped to house. No I have no affiliation to Amazon. Simply sharing with my fellow RV'ers. Have a good day.
https://www.amazon.ca/Combi-Cam-7850...001273536&th=1
