It could be anything but the light switch or water heater are the most educated guesses.
If the switch is "Off" but the light still turns on with the center button, it's not that.
If it's for the water heater, it's worth a test. With the WH full of water, have the switch in the bathroom turned to "Off" and the switch on the WH turned to "On". After 2 hours, if the water is hot, the switch in the bathroom is not for the WH. If the water is still cold, turn the switch in the bathroom to "On" and check again in 2 hours. If the water is hot, then that's your switch.
On a side note, our WH only has the electric control at the WH itself. If plugged in to shore power or at the house, we use electric. To help boost the WH after showering we use the propane in addition to electric.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
