Furrion observation camera replacement
Ok, its time for a replacement. My surveyor isvprewired. I've had the camera for only 3 years. Paid like 350 then. now they want 488 plus as a replacement. I have been researching if it can be fixed and it appears that it can not.
I have found Tadi brothers have camers with an adapter kit that will still just plug into the prewired that i have. I have to install a bracket in place of the furrion bracket, but the bracket has several openings. when i remove the cover off the furrion it has quite a bit opening that does not appear to seal that opening with the tadi brother bracket. Anyone used tadi brothers furrion kit and camera. They seem much cheaper than furrion.
Also found Haloview 7108 or MC5111. I believe these require cutting the prewire on the trailer which i rather not do. Anyone use either of these.
Thanks in advance for any help/suggestions. I really want to just plug back in like the furrion was and it work.
