I installed an Easystart on my Dometic Brisk 2 15,000 BTU. I have a pair of Honda EU2000s. Without the easystart I had to parallel the Hondas to operate the AC. When I tried to run the AC (and all other breakers off) on one Honda, it would trip right off.
After installing the easystart, I can run the AC on one Honda. It does run “wide open” and sounds strained. The Honda is “rated” at 1600 watts, with a “maximum” of 2000 watts. When I measured the load, it was around 1800 watts. It was about 85F and I am at 15’ elevation.
Not sure what your generator produces. Hope this helps.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
