Old 09-18-2021, 03:20 PM   #1
Run ac on 20 amp
As you can tell I know little. I have heavy duty cord. Plugged into 110 outlet. My RV only uses frig on 110. If I turn off frog think I can run 13500 btu unit for bedroom only?
ronthet is offline   Reply With Quote
Old 09-18-2021, 04:14 PM   #2
bikendan's Avatar
My 20 amp outlet is able to run my 13.5k a/c IF there are no other AC power demands.
Old 09-18-2021, 04:14 PM   #3
Flybob's Avatar
How heavy is HD extension cord?
How long is HD extension cord.?
Your converter will use some 120V
What else in your garage/home is on that breaker?
Is the home/garage outlet protected by GFCI?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-18-2021, 04:29 PM   #4
I use a heavy duty 12ga extension cord and have run my AC on 20A with no issues. The frig can always be run on LP if so equipped.
phipps33 is offline   Reply With Quote
Old 09-18-2021, 07:38 PM   #5
X2!!
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is online now   Reply With Quote
Old 09-18-2021, 08:13 PM   #6
As others report, mine works fine that way. Use a heavy gauge extension cord and keep it as short as you can. If your trailer power cord will reach the power source, eliminate the extension cord by using a 15A male - to - 30A female dog-bone adapter. One having 90 degree plugs is better than one with straight plugs. It takes the strain off the cord. (But it's not really a big deal.)
https://smile.amazon.com/dp/B000BUU5YA, less than $10.
- 2016 Ford F-150 SCrew Lariat RWD MaxTow
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 09-18-2021, 08:42 PM   #7
Now a "Top Member"
EdJunior's Avatar
I don't usually use my frig while my 5er is parked at home, though I do turn it on prior to a trip to get it cooled down. But when I go to work on it, or clean, or to use when family or friends come in. But I can usually run the AC, the TV, a computer, and a couple of plugs to charge phones. And the lights. Mine is a 20 amp plug. Sometimes something will trip the breaker, but not too often.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 09-19-2021, 12:57 PM   #8
Yes. Do it all the time on the 18,500 unit.
Lfresin1 is offline   Reply With Quote
Old 09-19-2021, 12:58 PM   #9
AD on 20 amp
I ran a 15000BTU on 20 amp with no problem. Use your RV cable with adapter to be safe.
AdamKam is offline   Reply With Quote
