Old 10-27-2020, 09:31 PM   #1
TV Bracket outside
There is a little plastic bracket on the outside of the 2013 Surveyor SP220 that supposedly holds a tv. Has anyone used this. Does it hold the tv that is inside the rv? Not sure how to use it.
goingrving is offline   Reply With Quote
Old 10-27-2020, 09:40 PM   #2
dbledan's Avatar
Mine holds the TV from inside on the outside. I chose to buy another mount and attach another TV outside when I want it.
One note is I use an older TV that is a bit heavy and I found that it squished all the butyl tape out on the bottom where a lighter TV did not do this so careful about too much weight.
dbledan is offline   Reply With Quote
Old 10-27-2020, 09:47 PM   #3
Thank you for your response. Is the outside mount the same as the inside mount?
Old 10-27-2020, 09:53 PM   #4
bikendan's Avatar
Pics are often more helpful than descriptions. FR brands use a number of different tv brackets.
