Old 03-20-2020, 08:14 AM   #1
Where is my converter? (Where is the code for my router?)
We bought a 2020 RKS 251 Surveyor Luxury and it has One Control. The only thing is that there is supposed to be a password inside one of the cabinets on a white sticker. I called FR and advised it is not there. Of course they said, "no it has to be". We have had 3 adults in there looking and nothing. They said on our converter there should also be a sticker with the password. Maybe a stupid question but where is the converter? FR said it should be in my fuse box in the back. I took that cover off and I don't see anything. Has anyone else run into this issue?
jhudson13 is offline   Reply With Quote
Old 03-20-2020, 08:20 AM   #2
have you asked the dealer to provide it?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 03-20-2020, 08:23 AM   #3
Oh Yes. Their response...One Control???????
Old 03-20-2020, 08:37 AM   #4
fonzie's Avatar
Most converters are with the Distribution panel. In a video, I can see that it is probably below the fridge next to the entry door.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-20-2020, 08:51 AM   #5
cavie's Avatar
It is part of or just behind the Fuse box panel with the circuit breakers.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-20-2020, 12:24 PM   #6
DustyRoads's Avatar
I have a 2017 251rks the converter is right below the refrigerator with the fuse box. I would check in the medicine cabinet which is close to the utilities control panel, if it is in the same location as mine. Or in the cabinet next to microwave. Good luck!!
DustyRoads is offline   Reply With Quote
Old 03-20-2020, 12:46 PM   #7
Mr. Dan's Avatar
jhudson13, have you located your converter? Have you looked where suggested?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 14; booked = 14
Old 03-20-2020, 12:50 PM   #8
Try 0000
boogiejack75 is offline   Reply With Quote
Old 03-20-2020, 01:41 PM   #9
Yes, found the converter but no password on there like FR said. Back to the drawing board. Tried 0000. No luck
Old 03-20-2020, 02:18 PM   #10
Coolharts's Avatar
Mine is behind my fuse panel. When everything is quiet turn on your lights in the camper, you should hear the converter making noise like a fan or it is a fan.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
2018 25 2019 25
Coolharts is online now   Reply With Quote
Old 03-20-2020, 04:45 PM   #11
Sorry about that. Mine was programmed 0000 from factory. There has to be some sort of password reset?????
Old 03-20-2020, 04:53 PM   #12
Mr. Dan's Avatar
He found his converter. See the post in front of yours.
Old 03-20-2020, 04:54 PM   #13
LCI says the pass word is on the wifi router. This is commonly in a cabinet somewhere in the center part of you rig. Also my 2020 coachmen has the LCI screen but only controls auto level the camper is not set up for the rest of the one control abilities so myunit does not have a router.
Meben is offline   Reply With Quote
Old 03-20-2020, 05:02 PM   #14
NMWildcat's Avatar
Are you sure they said converter? I helped my friend set theirs up and the login/password label was on the WiFi router. We used that and an Ethernet cable to to log into the admin interface and configure.
You can find instructions for your particular system in the Lippert master manuals https://support.lci1.com/master-manuals/
I believe Electronics is where we found the detailed instructions.
Scott and Liz - Southern NM
Old 03-23-2020, 08:01 AM   #15
Yes. I also called Lippert directly and they told me the same thing. He walked me through it as I was on the phone with him.
Old 03-23-2020, 08:48 AM   #16
Chuck_S's Avatar
All this was about a wifi password?! Too bad we all thought it was about the AC-to-DC converter.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 03-23-2020, 08:51 AM   #17
This was in the first line original post........We bought a 2020 RKS 251 Surveyor Luxury and it has One Control. The only thing is that there is supposed to be a password inside one of the cabinets on a white sticker.
Thanks for all the responses and sorry to have inconvenienced anyone.
Old 03-23-2020, 09:07 AM   #18
NMWildcat's Avatar
No inconvenience at all! If we didn't want to participate in this forum, we wouldn't
Just glad you got it going. I have found most manufacturer tech support very helpful. Also the Lippert master manuals are a great resource.
I'm still trying to convince myself that the One Control is a step up in convenience, but seems like they can also be a new major source of frustration! But, like everything else, they come with a learning curve.
Happy RVing!
Old 03-23-2020, 12:20 PM   #19
Chuck_S's Avatar
No mention of Wifi in #1. Subject is where is my converter. Should have been "where is the code for my router." One Control (I assume is a brand name) and is just what, a router?
-- Chuck
Old 03-23-2020, 12:22 PM   #20
NMWildcat's Avatar
-- Chuck
Most of us knew what he was after, and he has fixed his problem. Why pick over meaningless details now?
If the title bothers you so much, petition the moderators to change it.......
converter
