The water pump on my 247 bhds is under the drivers side storage compartment. There should be 4 small screws holding a panel to the inside wall. The water pump should be behind the panel.
The hot water tank was pretty straight forward. Open the relief valve and the remove the anoid rod. I used compress air to assist will purging the water lines and faucets to include the outside shower . Then shut the valves off for the hot water tank and then pumped the antifreeze through all the line, faucets,shower heads etc. Pour a little in all the sinks and drains as well. Do not run the anti freeze through your hot water tank.
