Old 02-15-2019, 04:20 PM   #1
2019 gray wolf 22rr water leaks
2019 Cherokee Gray wolf 22rr has water between frame rail and outside wall in the liner in the insulation. And I checked a new one at a dealer . Same thing water. Something is leaking on the right side . Not plumbing related. Anyone notice this? You should go look. What to do?????
spoffordca is offline   Reply With Quote
Old 02-16-2019, 10:47 AM   #2
Do you have a picture of the area your talking about. About to pick our 2019 22RR up next week. Want to check this before I leave dealer.
zayers is offline   Reply With Quote
Old 02-16-2019, 01:52 PM   #3
Full of water but frozen now . It is frozen insulation. I think it may be coming in from the awning gutter .Water under the awning in a few spots noticed dipping down the outside wall when it rains.Click image for larger version
Old 02-16-2019, 01:55 PM   #4
Originally Posted by spoffordca View Post
Full of water but frozen now . It is frozen insulation. I think it may be coming in from the awning gutter .Water under the awning in a few spots noticed dipping down the outside wall when it rains.Attachment 196951
It should be soft and fuffy not a frozen mass
Old 02-16-2019, 03:06 PM   #5
Thanks for the picture. I’ll check it when I go to the dealer.
Old 02-16-2019, 03:28 PM   #6
Be careful dealer said water heater leaks was the cause. .not.. the water heater and all water is all on the left side on a 22rr except for kitchen sink(not leaking) it is winter no water in the sink area..
Old 02-16-2019, 08:27 PM   #7
Jetlag_bc's Avatar
As the snow melts, mine is leaking from a ugly splice near the awning. Its running down on the outside with nothing in its path to make the water go inside.
ID:	196979   Click image for larger version
2019 22RR
2017 Ram 3500
1972 HD FLH & 1998 HD FLSTS
Jetlag_bc is offline   Reply With Quote
Old 02-17-2019, 06:07 AM   #8
That is ugly. my splice was on the other gutter on the driver side. A dab of silicone on the outside bottom stopped my leaking gutter. Feel the liner it should be soft and dry not a frozen block of insulation. mold is my concern. In the spring when it warms up. I don't like the thoughts of what will happen. Rolling Mold . Water is the death of a tt. I will trade asap..I haven't even used it..sad camper.
Old 02-17-2019, 09:23 AM   #9
Full of water Click image for larger version
Old 02-17-2019, 10:41 AM   #10
AZ Pete's Avatar
"Trade"? Are you talking about having it replaced under warranty?
AZ Pete is offline   Reply With Quote
Old 02-17-2019, 12:20 PM   #11
No just trade ...at a loss and get one that has no water in it..this one will never be right water in the wrong places
Old 02-17-2019, 02:24 PM   #12
Carknocker Family
Ida Ratherbe Camping's Avatar
I would at least poke a hole in cover to let water out as it melts. What opening on that side of tt.? Window, vent for stove ? Our stove vent leaked when we first got it. Bad caulk joint.
Ida Ratherbe Camping is offline   Reply With Quote
Old 02-17-2019, 02:50 PM   #13
poke a hole then go find the leak!
cavie is offline   Reply With Quote
Old 02-17-2019, 03:35 PM   #14
Originally Posted by cavie View Post
pole a hole then go find the leak!
Brand new unit... poking holes? Then what? Dry and except ??? New unit?
Old 02-17-2019, 06:33 PM   #15
Carknocker Family
Or do nothing let it rot, talk bad about manufacturer, trade it in, let it be someone else's problem.
Most people come on here for suggestions on how to fix and ideas on where to look.
If you don't want to do either, see first paragraph.
Being a new unit it can be fixed with minimal damage to tt. Still under warranty, take it to dealership for repairs.
Old 02-18-2019, 04:03 AM   #16
This may very will be a 30 min repair and a non issue for years to come.
It's very obvious you are new to the RV world. You will NEVER find a unit without some sort of problems. You must be willing to learn to do your own repairs or live near a dealer and be very patient while it sits on his lot waiting to be repaired.
There is NO quality control in the RV industry. It's all "buyer be wear".
Old 02-18-2019, 06:13 AM   #17
Ok I'll buyer beware
leak, water, water leak
