Access to by-pass valves made easier!
One of the problems I had after I had bought my 2019 Cherokee Gray Wolf 22RR was trying to reach the back of the water heater and the by pass valves. The way the dealer sales person explained it was: you have somebody hold the mattress support/ aka a piece of osb, up or a support pole and you crawl under the support and reach over a piece of paneling and turn the two valves on the rear of the water heater off or on.The alternate way is to crawl thru the front storage space and reach over the piece of paneling again. Well I fumbled around and figured out that I could carefully cut a hole into the storage area and cover the hole with a piece of thin plywood to keep the mattress from sinking into the hole. Low & Behold it worked! Now all I have to do is slide the mattress away from the front wall of the trailer pop open the door/cover and turn those valves as easy as pie! Yahooo! God I Love it When a Project Turns Out The Way You Thought It Would!
