Originally Posted by ruddie66
So here’s the latest. Found an actual cable splitter buried further up in the ceiling. This is from LR cable connection plate. All 3 cables attached to this new found splitter were some what lose. Tighten all, retried tv in BR, now have 5 of 7 channels. That’s as good as it gets. Thanks for your assistance.
Make sure the cables are on the correct ports of the splitter.
It should be marked. Some ports may have better pass-through abilities.
It will likely work wherever they are connected to but 'may' work better if connected correctly.
