07-29-2012, 07:04 PM
fuel station not working
I bought a new wolf pack 305 5th wheel the dealer did not show me how it works,its 3.5 hour drive to the dealer. The next week we packed up to go camping filled up the tank with gas to run the toys couldn't get the pump to turn on.replaced the fuse.it still wouldn't work.had to go get gas at the gas station.
07-29-2012, 07:07 PM
There is switch down near the filler was it on turned on?
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
07-29-2012, 08:08 PM
I've tried the switch in both directions the pump won't come on the guage lights up but no punp
07-29-2012, 08:23 PM
From what I can see on mine the only other simple check would be the wires around the pump. Or the switch could be bad. Could you try hard wiring around the switch to eliminate the switch.
2013 Toyota Tundra
07-29-2012, 08:36 PM
Pump is jammed. I wired a reversing switch so I could run the pump backwards. That usually clears the pump when it is jammed.
Every month I run the pump for 5 minutes in recycle (fuel from the nozzle into the tank). That seems to keep everything running OK.
I don't know about all the fuel stations but if yours is like the one on my Palamino if the the gauge is working so should the pump.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
07-29-2012, 09:24 PM
Does your fuel station have a 5 minute timer at the gauge?
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
07-30-2012, 05:25 PM
fuel station
yes on the timer, i checked again and it blew a fuel. I havn't had time to check the wires at the pump.
08-03-2012, 01:09 PM
I am guessing you meant "fuse." That really sounds like a jammed pump. When the pump's rotor is jammed, it stars pulling a lot of amps and eventually blows the fuse.
If you can reverse the pump's power polarity, you can reverse the direction of the rotor. This can help dislodge whatever trash may be jamming the rotor.
On my system, besides the timer inside, there is an on/off switch at the fuel station. When I reverse the power, I turn the on/off switch rapidly on and off until I hear the pump running, then I turn it off. Then I return the polarity to normal and run the pump in recycle for several minutes.
Every month I run the for two or three minutes in recycle to keep the pump running.
One thought about this too. I wonder if the pump is swelling because of the ethanol added to fuel?
09-28-2012, 01:27 PM
2011 Forest River Stealth
02-13-2013, 10:21 PM
read through those posts and they are right the plastic gear actually swells and jams. there is a lever or handle at the pump under the camper because it is the same thing you'll find on the fuel tanks on ranch and farm trucks for fuel tansfer. if the gear has swelled you'll have to pull the side cover of the pump itself and pull the gear out. if it has swelled real bad pulling it out may require a slide hammer which i have experienced myself twice in 1 year and I don't haul anything but premium fuel for my sand rail! this was on my old 30 wp anyways. you'll have to sand down the side of the plastic gear. I have though about machining some aluminum gears but haven't yet. wish I could find 1 for sale but have never been able to find 1. I had to take a file to the tips of the plastic gear once as well as sanding the side down too. if you loosen the 4 bolts on the side plate and it starts then that is definitely the problem. if it is really jammed then it still won't spin.
07-13-2014, 11:21 AM
2011 XLR toyauler
My problem is not the pump, took pump apart sanded the gears, tested it, pump ran fine. My problem is with the little box that the wiring hook to. KIB# DTM101-5M. I have power in but not out. Having trouble finding a replacement, any suggestions?
07-13-2014, 12:03 PM
I started running that Lucas fuel additive two years ago and have never had a problem since with the pump gen. or bike carbs.
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
07-13-2014, 02:50 PM
good to know and i have used sea foam in that tank i had issues with after the first problem. still happened a second time too lol so i don't use the fuel station on my 295 wolf pack .
'99 f350 drw
'21 dune sport fire storm custom toyhauler
07-13-2014, 02:52 PM
when i do a search on that pn # it comes up as a fuel gauge set. do you have a pic of the box? is there a ground wire coming out of the box that may have been cut or un hooked? if the box has a built in relay then a dead ground wire would keep power from exiting.
'99 f350 drw
07-13-2014, 08:26 PM
Thanks dsrace,
I donot have a pic of the box, but all the wiring from the camper go into one plug with four wires, green, blue, red, and white. White being grd and red being pos from camper wiring. the box has same. Coming from box blue and green go back to feed fuel gauge set which has a switch to turn on pump.
07-13-2014, 08:35 PM
Thanks dsrace,
I'm pretty sure I checked all wires, but I will check again this coming weekend. I donot have a pic of the little box, it's about 4"x3" with green, blue, red, and white wires coming out which plug into the harness from the camper.
10-28-2014, 11:08 AM
KarlSr did you ever find a timer? Mine is out also.
10-28-2014, 03:11 PM
Sure did, I contacted the manufacturer and ordered it about $40.00 now I have to find out how to prime the pump because I had taken it apart and sanded the gears
10-28-2014, 06:14 PM
sorry didn't check back a while ago on this post but sounds like you figured it out and the timer would kill the power. the pumps really are not a good design imo but i will say the one on my 2011 295 wp is diff than the on that was on my 06 30wp! i have never used the one on my 2011 because the bad memories from the one on the 06 still haunt me lol well that and the 24" fuel line that won't even reach the ground. i really think we'd be better off with a hand crank gas caddy.
http://www.amazon.com/Gallon-Caddy-G...ords=gas+caddy
'99 f350 drw
