Old 03-15-2023, 01:32 PM   #1
Fuel Station Not Working After Tire Blowout
Recently experienced a tire blow out on my 5th wheel Cherokee Wolf Pack 335 toy hauler. The shredded tire also hit the wiring to my fuel station. It didn't appear to damage any of the wiring only tearing is loose where the excess wire was tie wrapped to under support bracket. However now the pump will not turn on nor does the light on the switch come on. The fuel gauge is working which would indicate the panel is receiving 12 volts. I checked the connectors and examined the wiring all the way to the pump and not able to see any damage. I checked the 12 volt fuses in the breaker box and none are marked for the fuel station nor are any blown. The switch panel-timer-gauge appears to be bad and is a sealed unit. Anyone experienced these going bad? Also where would the fuse for the fuel station be located? Are the wiring diagrams available anywhere for the pump switch and fuel gauge?
Name:	Fuel Station.jpg
Harold Beavers is offline   Reply With Quote
Old 03-15-2023, 02:49 PM   #2
Is the switch getting power I doubt they both run off the same wire
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
Old 03-15-2023, 05:38 PM   #3
Not able to access the switch to get a volt meter on it. The switch, 5 minute timer and gauge are all in what appears to be a sealed unit. There’s a connection on the wires that come out of the switch but not sure what wires to check.
Old 03-15-2023, 06:13 PM   #4
bikendan's Avatar
Moved thread from the General Tech and Repair section to the Cherokee sub-forum, in the Toyhauler section since Toyhaulers are the only RVs with fuel stations.
Old 03-15-2023, 07:49 PM   #5
My rv mechanic took mine apart and put it back together to get mine to work.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
fuel, tire
