07-07-2020, 09:32 AM
Gas Grill
What are you guys using for gas grill?
07-07-2020, 09:51 AM
22" Blackstone Griddle
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
07-07-2020, 09:55 AM
Weber Q 200 and Blackstone 17"
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
07-07-2020, 09:57 AM
Me too. Ive got the one from walmart that includes a stand, hood, regular propane connector, and small bottle propane connector. I purchased a low pressure connector and hose to connect to the low pressure connector on the camper.
Easy to set up. Easy to clean.
07-07-2020, 09:58 AM
Grills
These are all table top from what I am seeing. Was thinking a frame hanger or mount would be nice to mount up front by gas supply. (22RR)
07-07-2020, 10:02 AM
We have used countless grills over the years but never really found 'The One'. We wanted something easy to clean, easy to store, with enough heat output to cook quickly.
I think we finally found a system perfect for our needs. We have been using this Camp Chef one burner. We use the BBQ grill accessory for grilling, and a home-made disco for frying/cooking when a solid surface is needed. It all cleans very easily and stores in a small space, each piece has its own storage/carry bag. The BBQ accessory fits on top of the burner, I just don't have a picture of us using it. The burner legs are very sturdy but come off for easy storage..
https://www.campchef.com/cooking-sys...-1-burner.html
https://www.campchef.com/cooking-sys...ms/pro-30.html
These are pics using the disco on top of the burner
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-07-2020, 10:22 PM
A Weber Go-Anywhere grill that was a wedding present 30+ years ago.
2011 Rockwood Mini Lite 1809S
2013 Rockwood Ultra Lite 2304S
2004 Dodge Dakota SLT+ 4.7
2012 Ford F150 FX4 3.5 EcoBoost
07-08-2020, 12:26 AM
I use a table with my blackstone and the lp port most of the time. It's super easy to clean. If the table is too close then I get grease all over the side of the trailer though. For this reason without a lid I would not mount my grill to the side. You can get them with the lid and table from walmart pretty cheap. I just keep mine about 8in from the trailer to keep the mess down. There is a decent conversion kit to attach easily to the trailer LP port. I wanted to do cedar plank salmon and had to use a charcoal grill from a friend...only complaint I have with it.
I have a coleman roadtrip that I used a few times. No table but more difficult to clean so I don't use it much. I used green tanks and LP port conversion I made from many parts. Has a burner griddle and grill attachments. Not a good idea to close the lid if on high.
I have used a Weber q 2200. It was small and easy to use with the lid. I used it with the green tanks on a picnic table and off the lp port on a table. Takes up storage but works well as a grill and fairly well as an oven. It was well used and had a few issues with grease in the LP tube so spent a lot of time cleaning it out.
I love my GMG Davy Crockett smoker as a grill smoker and an oven. Easy to clean, heavy to haul and store and requires pellets but worth the time. Works on a table (as long as you are near an edge for grease) or on it's own legs. Does not fit under the truck cover though and the short spring legs suck to move it. It also requires power but works 12v or 120. I use a 12v battery box.
I trashed the hunk of junk that came with the trailer after the first trip. It took forever to cook a burger and could only fit 4 of them.
07-08-2020, 12:33 AM
We have a Blackstone 22, and a Weber Q2000. Since we got the Blackstone, it probably gets about 90% of the use, and the Weber Q about 10%. But, that being said, I don't love the Weber Q any less.... it is just testament to the fact that you can use the Blackstone for so much.
As far as grilling, you can come close on the Blackstone, very, very, very close. But the Weber always wins out for grilling pork steaks, beef steaks... You can't get flame kissed meat on the Blackstone.
Brian & Becky
2018 Avenger ATI 27RBS
07-15-2020, 08:34 AM
Weber q1200
anyone using the Q1200 did you remove regulator to use quick disconnect on 22RR supplied valve?
07-15-2020, 08:59 AM
A $20 Wally World propane grill converted to run off the low pressure quick connect port.
Makes everything we like to eat just fine.
07-15-2020, 09:40 AM
Location: Alberta - East of the Rockies, West of the Rest
Camp Chef 2 burner stove with single burner grill box, single burner griddle and with the dutch oven the sky is the limit. This thing is incredible!
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
07-15-2020, 09:50 AM
RV There Yet?
we use a Coleman Road Trip grill. we have a griddle insert on half of it and love the way it works!
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
Canadian Member
Weber Q2200. I just converted it to connect to the RV’s propane system. We don’t and won’t own a Blackstone simply because we don’t fry much of our food so a simple frying pan suffices for the few times we do.
07-15-2020, 09:52 AM
There are multiple YT videos on converting the Weber Q series grills to the LP quick disconnect. I've been using mine for years that way.
Hobienick
2022 Grand Design Imagine 2800BH
2020 Rockwood Roo 19 (Sold Jul 2022)
2012 F150 SuperCrew Ecoboost
